joined the timing belt club at ~ 87k
Old 02-26-17, 06:57 PM
  #61
02Legend
02Legend's Avatar
Originally Posted by Tom57
It does matter. There's only one (correct) way to put the timing belt on.
Yes, of course the engineers did. That's why the belt is marked "R-CAM" and "L-CAM." The R-CAM is the passenger side, not the driver's side. That is likely where the error was made by 02Legend's tech.
I agree that with putting the belt on wrong most definitely caused damage, and most likely to a valve or valves at this point. Only downside is that it will have to wait 3 weeks until I return from business travel.
Old 02-26-17, 08:12 PM
  #62
Tom57
Tom57's Avatar
Hang in there and don't sweat it, especially while traveling. It's definitely repairable.
Old 02-27-17, 12:32 PM
  #63
Johnhav430
Johnhav430's Avatar
Here is a documented case, tutorial, where the belt is totally on backwards. The user has R and L mistaken, and his arrows are lined up, but facing the wrong way, pointing to the back.
He said nothing was wrong, and acknowledges it's backwards. Again, my hunch is the arrows serve the purpose of making sure the number of teeth are correct i.e. spacing. Because it's being installed in a slackened state, how else would one know how to put it on? But in my analogy, if each mark is 17 teeth off, it would still be the same...my .02. I know, there's no reason to put it on backwards, but I'm trying to establish that it doesn't seem like it makes any difference, unless the teeth were wrong....
Again I hope maybe there is nothing wrong with 02Legend's car....
https://www.yotatech.com/f28/tundra-...l#post51580474
Old 02-27-17, 02:41 PM
  #64
02Legend
02Legend's Avatar
Thanks for sharing the link. Just quickly glanced it and see he stated his was on backwards but is not having any issues. I just landed in dreary rainy San Diego and will read it more a little later.
Old 02-27-17, 06:18 PM
  #65
Tom57
Tom57's Avatar
Anyone can install a timing belt backwards and move the cams and crankshaft to get all the marks to line up ... but that doesn't mean it's installed correctly. Faulty information drawn from a different engine isn't reliable.
The provided link is a 2UZ engine (4.7 L), not the 3UZ. There's one pic in that thread which demonstrates that a backward installed timing belt would result in incorrect valve sequence. Note where the crankshaft belt timing mark is at 5 o'clock with the belt ostensibly lined up with each of the 3 timing marks. Now imagine flipping the belt. The cams would not move to line up the cam marks but the crank would have to move to 7 o'clock to line up the crank timing mark. That shows there are two (2) different timing results using the belt correctly and backwards.
Read the many good threads with specifics regarding where the crank and cams must be when the belt is removed and replaced - since you don't want the cams to be under stress from the valves in open position and move while trying to install the new belt.
Why did 02Legend's tech who knew how to do timing belts say the belt was backwards? Because he knew that was a problem. Why is the belt marked R, L and Crank? Because it's installed correctly only one way.
Old 02-27-17, 07:10 PM
  #66
Johnhav430
Johnhav430's Avatar
it is puzzling to see the CR with the arrow pointing backwards, not at 6 o'clock. The way the guy did his tutorial, for all we know he corrected it, because some of the labels for the pics are incorrect, as if edited, I.e.left label correct, pic showing R.
i'm going to count the teeth to see if the marks are symmetrical. Not in the next few days, though.
the thing about 02's job, did the shop button everything up, start it up, and get timing advanced, and then open it up again? That is a ton of labor. Or, did they start it up, get timing advanced, and the code went away? When did they decide that the belt was backwards? What did they think the incorrect orientation did? I have changed many serpentine belts before, and I never really gave it any thought. And as mentioned, if I went by the word Toyota on the 3uz belt, it would face me, and the arrows would point back. The belt would now be backwards. That's counterintuitive on Toyota or Mitsuboshi's part.
Old 03-02-17, 06:38 AM
  #67
e60bmw
e60bmw's Avatar
I really need to get mine done soon, have 97k currently.
Old 03-02-17, 07:47 AM
  #68
Johnhav430
Johnhav430's Avatar
I believe an indie is about $700-$850 for the timing belt and water pump "job"....I would ask them if they're going to include the tensioner pulley, idler, and tensioner, and also pink Toyota coolant (forget what year, 05+?), and if they have ever done the 3UZ before, to me it makes sense to do the serpentine belt too since there is no add'l labor, but I was told there's really no need to do the thermostat or hoses unless there is a problem, which they would tell me if they come across it...no need to learn on our cars....I'd rather hear, no we haven't done your car before, and go elsewhere, than to be told, your car won't be ready today, we need another day (something is wrong at this point, I think it's a 3-4 hr. job by a specialist)....
Old 03-03-17, 09:09 PM
  #69
Gronemus
Gronemus's Avatar
Lots of good information about timing belts in this brochure from the land down under...
http://www.gatesaustralia.com.au/~/m...ing-manual.pdf
Old 03-23-17, 07:33 PM
  #70
02Legend
02Legend's Avatar
Not sure if anyone is still checking back in here, but I am taking my car to the dealer on Saturday and hoping they can "actually" diagnose the issue on Monday and possible have it fixed. Otherwise, my car will be sitting at the dealer for almost a month (they agreed to let me leave it there). I am flying back home tomorrow and just found out my company needs me to fly back out A.S.A.P to save grace with a customer. So, hopefully I will know by Monday, if not, during next week and get it fixed. I will update when I hear from the dealer.
Old 03-23-17, 08:34 PM
  #71
tallcaguy
tallcaguy's Avatar
Sorry to hear. It sounds like a monumental PIA. Good luck. Hope things work out!
Old 03-25-17, 01:40 PM
  #72
02Legend
02Legend's Avatar
It has been a pain. Good thing is I am very patient. Dropped the car off at the dealer earlier and was told it was going to take priority Monday morning as the service guy wants to have the car fixed and not sitting there for 20+ days. I did ask that they just double check the timing belt and timing, as well as the rear passenger spark plug since the plugs were changed.
Old 03-28-17, 08:54 AM
  #73
02Legend
02Legend's Avatar
Just got a voicemail from the dealer. They did a leak down and compression test. Said all was good, but said that I would need valve(s) adjusted. Got a lovely quote of $2400. Don't know if that's high/low or about average. Trying to get a hold of another dealer in my area for a second quote.
Old 03-28-17, 08:59 AM
  #74
Johnhav430
Johnhav430's Avatar
Good to hear that (all was good except)....I wonder how necessary it is, my Maxima has manually adjusted valves and I never did it in over 240k. But if you were to do it, can we apply the indie rule that it should cost maybe about 55% of the dealer quote....so if you really want to do this work, would it be maybe $1300 at an indie? Seems like too much to spend on an older car, I mean we all consider the timing belt to be a major job even at $700-$850, so I'd be hesitant to spend any more than that on our older cars....my .02
Old 03-28-17, 09:03 AM
  #75
02Legend
02Legend's Avatar
My buddy (shop that did the timing belt) said he could check with his guy and see what it would cost. Right now, I'm considering the dealer, in that way if anything happens or is not correct, it would be less hassle to get things resolved.
Quick Reply: joined the timing belt club at ~ 87k
