Replaced air strut, still sagging.
2001 UL, had a leaking driver front strut. Replaced with new OEM strut, everything went back together without issue. Fired car back up and no movement at all out of the new strut. No signs of air leaks, but also no obvious sign the compressor is kicking on.
Anyone have troubleshooting advice for checking the air suspension compressor?
Thanks in advance.
Thanks in advance.
Start with disconnecting the negative cable to the battery for a few minutes to reset the air suspension system.
Also check Post #4 on the link below:
https://www.clublexus.com/forums/ls-...lt-change.html
oldkystude
06-21-16 03:30 AM
wortex
01-18-12 08:20 PM
