06 Trunk fuse?
06 Trunk fuse?
The switch inside my car for the trunk release doesn't appear to be working. The smartkey button as well as the button on the key itself will open the trunk. Ideas?
Ironically I am having a similar problem with my trunk. THe button on the back just stopped working. Even if I have the key in my pocket or in the car when you hold the button for about 3 seconds it would open the trunk. The switch inside under the dash still works and will the smart key button. If there a fuse or something?
Wow is right... Good catch.. Similar thing when I had my RX300. I thought the seat memory didn't work for about 2 years, until I read and re-read the manual on programming the seat memory buttons, after which I still didn't get it.. Finally did figure it out, though. I even spent money on a new seat ECU thinking it was bad.. And I AM a mechanic!!
