Drive side Chrome Door Moulding Trim
Does anyone know the part number for the Chrome Door Moulding/Trim on the driver front door? I Have this diagram but i'm not sure which is which, any help or has anyone changed these before? I don't need the whole panel just the moulding and I noticed today when taking it apart it actually acts as a bracket for the door panel. any help would be much appreciated, thanks!
This may help;
75736-50040.
I found this on this site;
https://parts.johnsonlexus.com/oem-p...JmE9bGV4dXM%3D
75736-50040.
Thanks for the info 2KHarrier, but after looking at the diagrams again I think it may actually be this part, the one you mentioned I think is the bottom black rubber moulding on the bottom of the panel. I think I may just call the dealers parts dept. and see if they can guide me.
I see that now. You're probably right. Yeah, give the dealership a call and at the very least, have them find the correct part number, then you can find it on line.
Sorry to bump this old thread, but can anyone confirm the part number and how to replace the chrome molding part pictured in the original post? It seems the interior door panel has to come off and then the molding needs to be unscrewed?
I believe the correct part number is 75736-50040 "MOULDING, FRONT DOOR OUTSIDE, LOWER LH"
75733-50040 seems to be the "MOULDING, FRONT DOOR, OUTSIDE UPPER REAR RH" aka the chrome molding below the window.
forumnoob
05-13-10 11:59 AM
