NEED HELP. Battery is being drained at 4.8 amps with the car off.
When you are testing for a draw It is recommend to lock the vehicle. The car goes to "sleep" much faster. Also it is recommended to lock your vehicle when not in use since it shuts down most of the computers (some people that park in a garage may not lock the car). These are amazing vehicles, I'm sorry you are having this problem. I hope you can sort it out soon. It's a shot in the dark but check the seat switches, I've had a few different customers where a seat switch was causing a draw on the battery.
I changed mine yesterday with a Bocsh AGM type, the old interstate Megatron II gave up...no start, since I am the 3rd owner and no document date from previous owner, I assume battery may be over 3+ years old. I borrow a Snap-on tools and did a battery test, it comes up these result, see photos, the blue one is the new AGM and I believed it's made by Excide.
Perhaps there is a micro switch that needs to be held closed.
Presumably checking current draw across the fuses inside the cabin will not be so easy if the alarm includes a movement sensor?
My '04 LS430 with new good quality battery failed to start the engine after 12 days [not completely dead] but it is good for say 6 days. Next time I will switch off the smart key system with the button on the dash but that should account for so much discharge.
Thanks for any contributions to this problem.
I don't think our cars are sophisticated enough (being 2001-2006), but I thought someone said our cars don't like AGM. I do know that in my BMW, if one goes from lead acid to AGM, the car needs to be coded and programmed. If a lead acid is replaced with a lead acid, then the car needs programming. The programming tells the DME that it has a new battery--if it is not told, it will charge the new battery as if it is x years old (however old or however long since the last programming took place). If our cars are not sophisticated like BMW, which I don't think they are, then the key imho is matching up the CCAs first, and hopefully the RC is comparable. but I'd be curious why someone said our cars don't like AGM....
I have been working nights since my last post. I will get off this coming Thursday so ill be able to pick this back up. GrahamG sounds like your having a similar problem. I am driving the ls 430 every day and checking the battery before I use the car. In a 9 to 12 hour period the battery drops from 12.4+ to 12.2 volts. Looking forward to the find.
Well i pulled all the fuses with no change to the amp draw. I am now looking at the alternator. Ill have to get the car picked up to disconnect the wire from the alternator and see if that is it.
Here is a thread regarding being unable to turn the wheel i.e. some sort of electrical issue....
https://www.clublexus.com/forums/ls-...ekey-turn.html
clp71220 (05-11-17)
Well sorry for the delay on this post. I had the alternator tested at an auto parts store and they said it checked fine on the tester they where using. However i was still not convinced that my alternator was fine. So i bit the bullet and had the Toyota dealership do a diagnostic check at $120 on the car for a parasitic battery drain. I said nothing about the alternator as i wanted to see what they would come up with. I was not there 15 minutes and they came back and said i needed to get a flooded cell battery before they could run the test. I guess they had a problem with the optima red top battery. So i agreed to return later with a flooded cell battery. I swapped battery's with my other car and returned and had them run the test and the Alternator failed the test and said it had a abnormal ripple. I guess this means that one of the diodes must be going bad or is bad. They wanted $900+ to replace the alternator and i have elected to do it myself. Due to work lately i have not had a chance to swap it out. But i will post back when i get this done and let you know if this fixed the battery drain.
Hello everyone. I got the alternator swapped out and so far so good. The charge rate is up to 14.2volts verses 13.6 volts and the parasitic drain is now at .15v to .30 volts probably the security system. I wanted to say thanks to all of you that helped with your post. I pray that God will Bless you all. Thanks
Another option for BT battery monitors:
This one has BT 5.3 and supports lithium batteries. It includes cranking and charging tests as well as base voltage monitoring.
I ordered one via Ali, $21 shipped (w/NY taxes), due to arrive 8 August.
