manually adding phone numbers to the 1 touch feature
any way to manually add phone numbers to the on touch feature of a 2004 lexus ls430 bluetooth? My Iphone 7 does not transfer contacts into the phone book
I have read that you can enter any important numbers into an Analog phone (that does not need to
have current service) and pair it to the 2004. Transfer your phone book. Delete that phone and you
should have a car based phone book that will dial your iPhone VII.
You can certainly position the phone where you can safely press the home key long enough for Siri
to trill and just command her to "call John Smith work" and it will then come through the BT system.
