How to reset VSC light, TRAC OFF Light and Check engine in the dashboard?
Suddenly on my LEXUS 430 VSC light, TRAC OFF Light and Check engine show in the dashboard.
How to reset?
How to reset?
First, let's make sure it is not a false alarm. If you have a OBDII reader, retrieve the DTC (Diagnostic Trouble Code) from the car, then erase the DTC and see if it would come back. If you don't have a reader, disconnect the negative battery cable for a few minutes to do a hard reset. This will clear the false alarm.
If there is really something wrong with the car (i.e. the lights come back), you will have to know the DTC to determine the next course of action.
