VSC and check engine lights
TTBomB (02-08-18)
#33
Hi Guys what a great Forum.
Today my Battery turned up dead because it was from 2014/2015.
An expensive X2 model from Batteries Plus
When I jumped the Car the dash gauges went nuts and I got the Dreaded Check VSC Message.
I have not been able to replace the battery because the whole state does not have one.
I may have the exhaust issue too because my car is mostly driven very short distances sometimes 2 miles and then right back in the garage after 10 minutes and stays there for 2-3 days without being driven.
Even the AC took a while to turn on after I had been driving for a few minutes to get to Batteries Plus and then the same thing happened on the Way back.
I will try and get the code read later today to see if I get the same ones above or different.
A Couple of days ago my garage opener control stopped working and perhaps because the battery was dying or dont know why.
How can I find a trustworthy mechanic or tell if they are giving me the correct answer.
I know the dealer will fleece me :-)
Plano TX area...
Plano TX area...
#34
Plano TX area...
Plano TX area...
#36
Any suggestions
have a ls430 2001
#37
I just got my cars system checked as I was getting check engine light along side the low level oil (which I think is the problem of the engin oil censor ) first on the system check the check engin lights went away for a few mins and then both vsc light and check engin light came on
Any suggestions
have a ls430 2001
Any suggestions
have a ls430 2001
genuinely your quickest way to know is to get a £30 code reader off amazon. You’ll know in minutes what’s up the know .
I did this and it’s a big piece of mind
#38
Gotta love the search feature. After 4 years over driving it 80 miles daily for work I finally got my first dash light combo matching these... I’m almost certain it’s an exhaust leak based on the startup smoke and exhaust smell. I removed the mufflers almost 2 years ago but about 4 months ago the exhaust started smelling. Gonna run the codes once I get my scanner.
#39
#40
To be fair I probably wouldn't worry too much. I stressed about this for ages. Change bank 1 o2 sensor, drove out of garage and had the exact same warning come back on about a mile or two later. I think its cat degradation but I'm kinda of the mindset it makes no difference to how the car drives so I'm not wasting the cash on a 17 year old car. It'll just keep running with a very occasional whiff of egg under full chat.
#42
Vsc and check engine light is showing in my car. this car i took recently..also previous owner he told me he replaced his battery recently..so is came because of battery replacement
#43
kim0217
10-30-15 04:02 AM
mkwon3
04-22-13 10:13 AM
boss22
05-02-12 04:58 PM
mchestnut
RX - 1st Gen (1999-2003)
09-02-08 06:15 AM
