Double DIN / Apple Carplay Install
#31
I don't have any pics, could try to upload some later, but the unit fits on the top shelf in my glove box (not sure if everyone has the multi shelf piece in the glove), I still have room for my manual and a few other misc. items in there while the vline is out of the way.
#33
It is responsive, however, it will not be the same experience as using a newer touch screen or android device, but it is definitely functional and once you learn the limitations it is pretty seamless and performs all the tasks I need it for.
#34
There is a small learning curve and adjustment period up front, but the added functionality makes all of the growing pains worth it. If you are somewhat tech savvy, you should not have any problems integrating the vline into your life.
Also, it sounds like there have been some software stability issues on people with newer model navs, but it has been stable for me since the update in December with a few hiccups along the way.
#35
Also, I forgot to mention, I do not notice any serious battery drain while using my iphone 6+ as a hotspot. I use it every day on my commute in the morning and I am typically around 97% when I get to work after about an hour drive, but YMMV.
#36
https://www1.crutchfield.com/p_500IL...e-iLX-107.html
I'm just wondering if it would fit since I have the UL controls at the bottom.
#37
Can you provide some more info on this? Any special trim that I would need to add something on a 02UL? I would love to add something like carplay to mine like this.
http://www.beatsonicusa.com/beat-sonic-mva-23l.html
#38
Mine is also a UL. The buttons for the UL fit in the blank spots below the radio. I just didn't put the height control switch in there because I have aftermarket suspension and it wouldn't do anything. Here is a link for your car if it's an 02 with navigation and Mark Levinson.
#41
The cost is what sopped me from changing out my radios in both of my LS'. I'm hoping to wire it up without the harness since I'm using aftermarket amps and speakers.
#42
I might just have to bite the bullet and do it, I've wanted a upgrade in my LS for some time now. I didn't realize it could be done again until I found this thread. I had looked when I first bought my LS.
#43
If you have the 04-06 then it's Beatsonic as your only option. Their kit does look pretty nice but it's so pricey. It't worth upgrading since the factory radio is terrible.
#44
If you have an older 01-03 LS you can use the Metra dash kit. I ordered one last week from Crutchfield for $35. I need to talk to my audio guy and see what we should do about the wiring.
So its just the trim and not the cabling?
#45
