2002 LS430 Radio wiring diagram please
Old 07-16-17, 06:49 AM
almeshtaq
almeshtaq's Avatar
Default 2002 LS430 Radio wiring diagram please
Hi ,
Can anyone help to show Radio wiring diagram for 2002 LS430 ..please...
Old 07-16-17, 07:59 AM
rkw77080
rkw77080's Avatar
Here you go...
File Type: pdf
Old 07-16-17, 11:57 AM
almeshtaq
almeshtaq's Avatar
Originally Posted by rkw77080
Here you go...
Thank you , this looks not clear to me !!!
I'm looking for Radio Harness pinout which is in the trunk ..
I mean Antenna wires,Power,Ground....... etc
Old 07-16-17, 05:25 PM
rkw77080
rkw77080's Avatar
How about now? Better?
Old 07-16-17, 09:32 PM
almeshtaq
almeshtaq's Avatar
I appreciate your kind help , but Still not clear to me ,I need pinout Antenna ,Power+, Ground -, with color of wires and pin numbers
Old 07-17-17, 07:29 AM
rkw77080
rkw77080's Avatar
As you can see on the wiring diagram, the LS430 audio system consists of 3 major pieces: 1) Radio and Player, 2) Stereo Component Tuner, and 3) Stereo Component Amplifier.
Automotive audio systems generally come with 2 power sources - one is constant 12VDC (always on), and the other is ACC (switched by the ignition). In the case of LS430:
1) Radio and Player has one of each of the 2 power sources. Refer to the wiring diagram, the switched power (ACC) is on connector R2, pin #11, color is grey. The always-on power (+B) is on connector R2, pin #1, color is light blue with yellow stripe. The ground wire is on connector R2, pin #20, color is brown.
2) The Stereo Component Turner has one of each of the 2 power sources. Refer to the wiring diagram, the switched power (ACC) is on connector S31, pin #14, color is grey. The always-on power (B) is on connector S31, pin #1, color is light blue with yellow stripe. The ground wire is on connector S31, pin #25, color is white with black stripe.
3) The Stereo Component Amplifier has two always-on and one ACC power sources. Refer to the wiring diagram, the switched power (ACC) is on connector S29, pin #20, color is grey. The first always-on power (+B) is on connector S30, pin #7, color is light blue with red stripe. The second always-on power (+B2) is on connector S30, pin #16, color is light blue with red stripe. The first ground wire (E) is on connector S30, pin #12, color is white with black stripe. The second ground wire (GND) is on connector S30, pin #13, color is white with black stripe.
The antenna cable from the rear window is connected to the Stereo Component Tuner (but it is not shown on the wiring diagram). Physical locations of the three audio components are depicted below...
Old 03-24-19, 06:25 PM
Nick724
Nick724's Avatar
Default 2005 ls
Here you go...
2005 ls430 ultra luxury to I was trying to fix the navigation player and made a mistake and grounded out the gray wire on back of navigation player now I think the amp turn on wire don't work it only works when I jump that gray wire that got grounded no fuses blow what could it be please help me
Old 05-24-20, 09:15 AM
jodyfletch
jodyfletch's Avatar
Making good use of this document now. Just wanted to say thank you!
Old 06-19-20, 05:08 AM
mdanfas
mdanfas's Avatar
Default Thank You
Thanks for the diagram
mrsandman
08-18-21 04:50 PM
premedmd
12-28-09 06:33 AM
Im2gq4u
05-06-08 08:46 PM
bri67ran
04-19-05 09:38 AM
Quick Reply: 2002 LS430 Radio wiring diagram please
