Mileage to Kilometeres
Hello, I have a U.S. used 2013 RX350 that I want to buy in Alberta and take home to British Columbia. It has all the 'readings' in Miles. Can I change this all to kilometers?
If not, as a second option, if I keep it the way it is, does ICBC require me to modify it once I get the vehicle inspection?
Jkallinen (07-16-17)
Right steering wheel spoke. Up/Down arrows normally take the Driver Info Display
on the dash between items you want to read...MPG, range, etc. Pressing the "Menu"
button briefly takes you to items you want to change..."Park" sensors, "Snow mode"
Press that button long enough and you will get into the setting that permit the English/Metric
display change you are looking for.
