Loosing its mind!!!
Loosing its mind!!!
For some unknown reason my 04 LS-430 is loosing its mind.
Sometimes everything is fine others it doesnt do anything right. Recently the seat settings are not being held and returned when the car is started. Sometines they are. Sometimes the mirrors turn down when I put the car in reverse and dont come back when I shift to Drive. Today the drivers window slid part way up and then stopped. after about 30 seconds it started working again. Is it secretly drinking???
jimisbell (08-02-17)
Are these issues happening intermittently or all the time?
How old is the battery?
Does this happen when its HOT? (get it tested then)
Point being last winter my wifes car needed a job 2 or 3 times randomly. Turns out a cell in the battery had finally conked out. It was under warranty. If this happens more and more, have it retested and see about a warrantly.
Even if the old battery costs to replace, you'd be replacing anyway. Maybe just a bit earlier than planned.
So clearly its an electrical issue. Did all the cells test OK in the battery.
The starting power of a battery (cca's) is only one of it's jobs. Once the car is running the battery acts as a filter/buffer for voltage spikes. An alternators output isn't "smooth" constant voltage. This is why all power connections are made at the positive battery terminal and not the alternator itself. As a battery ages it loses its ability to filter out these spikes and then passes them on to the electrical system which is composed of sensitive electronics.
That said, your problems may be elsewhere. Are all the issues you are having (memory, window, and mirrors) all occurring on the same door? If so you may have a bad ground connection or a failing door ecm.
DaveInMesa
RX - 1st Gen (1999-2003)
05-07-16 08:48 AM
