Having some problems with the aftermarket LED tails for 01-03.
Yeah I finally got these and have them installed carefully so no cable got pinched.
And the problem I have is that the position lights of the bottom row of the outer taillights doesn't lit.
The break light works fine. And the bottom row on the inner taillight do work when i use FOG light.
So im a bit stuck here. It is a Japan made LS 430 and was sold in Europe if that has anything to do with it.
Please help
Please help
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/1500x1064/led_tail_4ddac9a76389b2c058e64b26d6843a252b600e9f.jpg)
So I have tried some different options... Tried without resistors, nothing except warning.
Tried to turn the light bulb contact... nothing. Tried to shake the contact in all diffrent ways.
I mean they work when you brake so there no error on the leds. But its like they dont get a signal from the position lights cable?... I dont know im a totally noob on electric things. Is there anyway I can messure that the bottom part actually get signal from the position light?
I had some issues similar, check out my thread back then.
https://www.clublexus.com/forums/ls-...aillights.html
Double check all the connections, I think I had one off causing the same problem.
lostape45
06-09-16 04:00 PM
