Did I broke it?
Did I broke it?
Today after a previous day with my stick shift car, 5gears, I jumped into the 430 in a hurry to make an appointment.. Threw it into reverse and backed out of the drive. In the street I put it into "D" and took off. AT 15 mph I put in the clutch and grabbed the gear shift and pushed it into "second". OOps, this has an automatic and I had pushed it into reverse.!! And it wasnt the clutch, it was the brake I hit with my left foot. Suddenly slowing down I pushed harder with the gear shift lever, must not have gotten all the way into second so push harder and hit "Park". Now it really slows down and makes a "buzzing" noise. Nothing very loud or dangerous sounding.
As I recover my senses and realize that I am in the 430 I stop the car, place it into drive and pull forward.....good, it still works. Stop and then put it into reverse....good still works. Then stop put it into park....good still holds. OK, nothing seems to be amiss. So I finish my errand, no noise , shifts perfectly and as smooth as ever.
Did I break anything???
That buzzing noise you heard when you shifted into park was the parking pawl trying to engage a spinning drum. The pawl is what physically locks the trans when placed in park so the car will not roll. Although I doubt you caused any damage, I would be cautious next time you park on an incline and make sure the pawl can still lock the drum as intended.
flashes23
05-20-17 01:40 AM
