Removal of chrome molding that runs along top of doors and molding on roof?
The chrome molding that sits on top of the door skin, do these just pop out or is there a screw somewhere holding them on also? Looking to remove all 4 (drive, passenger, driver rear, passenger rear).
Also the drip rail, molding on the roof, does that also just pop out?
Thanks
Thanks
The drip rails are easy, no tools needed....I replaced my driver side because the vinyl had peeled quite a bit....the pass. side, I used clear packaging tape to prevent the peeling as it had started...
The easiest way is to start at the windshield. Undo with your hands those vertical moldings....now, you can easily lift up the drip molding starting at the front. Can't think of any other analogy, it's as easy as undoing Legos and snapping them back....just don't bend it and keep moving to the back, nothing needs to be replaced (clips)....good luck
don't know about the other...
Drip rails pop right off. Start at the rear and work forward... use a plastic trim removal tool. There are five total clips... shouldn't break any if you are careful. I had mine wrapped in gloss black vinyl... cost $115 and looks great.
fife199 (10-17-24)
Looks great, I think I’m going to order some vinyl to do this.
I actually had never noticed drip rails before, and now realize all of our cars except the 1998 Nissan have them. When I took mine off, pine needles and dirt (mud) was under it, amazing but when you look closely, there's only a tiny plastic squeegee like part that would keep stuff out...it the vinyl is peeled off then it looks stainless...imho I bet most are like I was, i.e. wouldn't notice drip rails on somebody else's car. Just that if the color wrap is loose and flapping, then sure others might notice...
Okay cool, so anyone have any idea how the molding at the bottom of the windows comes off, btw I am talking about this piece...
https://www.ebay.com/itm/Front-Door-...JZAHbC&vxp=mtr
Does it go all the way down to the windshield to the hood or is that a separate piece? also clipped in?
Sounds like either way they come off relatively easily?
Thanks.
The front part sort of slips into the one that runs up by the A-pillar. It was easier for me to start at the rear and when you get to the front, it just slips out due to the angle. You could probably start at the front, but I was wary of putting too much pressure on it and breaking it.
Did you break any clips?
The guys at the end of this thread says they all broke:
https://www.clublexus.com/forums/ls-...rip-rails.html
