chocking at 3K RPM?
Old 11-19-17, 08:18 AM
coug66
coug66's Avatar
I replaced the drivers side valve gasket a couple of times. And in the process thought that I was rough with the wiring. I actually disconnected 2 wires from one of my injectors. So I am wondering in that process if I might have disconnected or caused a MAF wire to short?
I will see this morning if I can figure it out.
Too many jobs on this car but I think that this will be one of the last for a while once I get it figured out.
Old 11-19-17, 11:49 AM
coug66
coug66's Avatar
Default This car is screweing with me
No power to the mas air flow sensor.
I can't get a power reading at the ecu. This car is screwing with me.
I have to walk away its cold and I am tired of being screwed with.
Old 11-19-17, 02:05 PM
rkw77080
rkw77080's Avatar
Maybe these will come in handy... Good luck!
File Type: pdf
coug66 (11-19-17)
Old 11-22-17, 12:35 PM
coug66
coug66's Avatar
Default What is the black wire to the MAF
maf wiring
Does anyone know if the B+ wire is a power wire? black Is E 12 a junction plug or?
since I don't have a hot wire to the maf, I am going to check the plug and see if I have continuity between the fuse and the plug.
Old 11-22-17, 12:59 PM
rkw77080
rkw77080's Avatar
Yes, the black wire to B+ is the power wiring (with ignition "On"), see wiring diagram below...
The junctions "EB2" and "E12" are both located in the engine bay...
coug66 (11-22-17)
Old 11-23-17, 10:59 AM
coug66
coug66's Avatar
Thank you so much for the help!!!! I ordered some back probes to make sure I have the correct readings.
I suspect that my ecu might be bad. I can't get any power readings from the ECU which is the second step in diagnosis.
Good news is there are plenty of used ECUs for around $100 on Ebay.
So instead of dread I am encouraged by an ECU problem. I would rather have an ECU issue than a wiring issue, much quicker to solve and I bet a new wiring harness is expensive and labor intensive.
What is NG and what is OK?
step 3 says check voltage
.5 to 3V
Ok= check and replace ECM
NG is check open or short in harness?
It seems backwards? Ok should be check or replace harness? but OK is check and replace ECM?
Maybe its stands for different meaning?
Old 11-24-17, 10:32 AM
coug66
coug66's Avatar
Default It's solved!!!!!!!!!!!!!
I followed the steps and wanted to see where the power was interrupted. It turned out the fuel injection 2 fuse was blown. Probably something I shorted at some point attaching and disconnecting something?
I reset and erased the codes and all the vsc and brake light check engine went off.
For the first time since owning the car I have a clean dash free from warning lights. The car accelerates above 3k!!!!!!
Wow so nice to have a victory!!!!
I couldnt have done it without the help from RKW!!!!!
Thank you Soooooo much!!
Old 11-24-17, 11:28 AM
rkw77080
rkw77080's Avatar
Congrats... Another success story!
Old 11-24-17, 12:58 PM
2013FSport
2013FSport's Avatar
Received 1,529 Likes on 1,272 Posts
If you were to take a wild guess, what killed the CATs? And how many miles on it?
Perhaps MAF was offline and it ran in limp mode too long whereby excessive fuel melts the honey comb and cracks it? That is an interesting failure.
Old 11-24-17, 07:05 PM
coug66
coug66's Avatar
Default I believe I had one bad and one good one.
i had p0420 and that cat had the issue. The other cat looks good and besides the dealer I don't know the other cat had an issue.
I think it had bad coils and probably pumped fuel into the cats.
The MAF and vsc was a recent issue.
I don't believe they had anything to do with the cats.
I had this issue with vsc after a removal of an O2 .
Not sure why the fuse blew?
Old 10-16-23, 08:15 PM
cvas
8th Gear
cvas's Avatar
I have the exact same issue. Where is the fuel injector fuse 2?
OMAHA
18
10-30-17 05:02 PM
shreddog
03-25-14 06:15 AM
andyboy
09-15-11 06:54 AM
jazz
02-01-05 09:45 AM
Quick Reply: chocking at 3K RPM?
