Interest in FIGS supercharger kit for 3uz?
I was speaking to Mike from FIGS engineering and he was discussing his interest in producing a supercharger kit for the 3uz platform. The kit would include intake manifold adapter plate, supercharger, fuel system, fittings, MAPECU3 piggy back ecu which will work with the stock ecu to help with fuel and such. He said the base price would be about $6000-$7000 thesis a base kit. There would be a turn kit available for more with plug and play harnesses and other things that would make it a plug and play installation. The results would be about 365-380 HP & 400 TQ these are just base numbers there are variables for every set up. The stock transmission will be able to hold the power.
I want to do the legwork for him because he has taken very good care of me and is always there to answer my questions and help me troubleshoot when needed. If anyone is interested please post below, so he can seeof there is enough interest to make a kit.
To be honest, if this kit is available right now, I would drop all my plans for a VIP build and just get this. This would make a hell of a daily.
I've heard LS3 swap is about 10k or something around there. This would definitely be cheaper and much easier to work with.
You get an lq4 or lq9 out of a GMC savanna van truck denali escalade for $400-$2500 use a t56 transmission use the t56 out of a corvette or camaro not a gto they are set up differently. Take the sikky motor mounts or cx racing install them in the is engine bay get a custom driveshaft made headers, use the stock gm ecu to tune, fuel pump, injectors, for the dash get a racepack gauge display and bam done deal that right there is $4000-$8000 if you can do the work yourself. I am going to be doing it to a 94 sc300 i live in NY and eveything must be plugged in and pass obd2.
So generally you guys would rather see a LS swap kit? What about gauges, OBDII and emissions?
Trying to offer a product that would be easily installed, roots type system if we can get hood clearance. Product delivery and viability would be dependent on interest. We will be upgrading our shop wagon and seeing what we can offer at the same time. Currently just for the blower is around 3K, so it will be a challenge to provide a kit in the 5K budget range.
Thanks Mike
Thanks Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
Thanks Mike
Thanks Mike
I've long thought my GS400 and now my LS430 were only needing more power to be perfect. I love everything about these cars....just wish they had a decent bump in power.
So yes, I'm rather interested.
Please keep me posted.
