Correct part # for the underhood plastic attachment hardware??
Hey guys does anyone happen to have the correct OEM part number for those little attachment hardware that hold down the under hood plastics on each side of the engine. There is a handful of them, mine have somewhat disappeared over the years I suppose lol.
This is for 04-06 LS430.
I took one out, went to the Lexus dealer, and he only had 3, gave me this
90467-09087-22
Someone else said that is not the right part per the diagram. It looks identical and I put them in, so I don't know, works for me. Paid 70 cents each on parts.com, I believe the list is like $1.01 or something like that...
90467-09087-22
90467-09087-22
THANK YOU for this information. I'll be buying a couple also!
I currently have some ROLL UP FOAM EAR PLUGS in the holes where the the grommet is supposed to go! LMAO! (I feel like a shadetree mechanic everytime I pop the hood and see the fluorescent yellow earplugs holding some of the covers in place), but hey---it prevents rattles beautifully! (well, functionally)
These are the correct part. Just did mine a few months back with these ones.
From the pics, those look stubbier than the ones in my car. Could be the width is interchangeable, and that they were already replaced in my car at some point with longer ones...at any rate, my local dealer charged 95 cents each (as opposed to 70 cents online plus shipping), so rather than do the above, one could get them locally for less...you're at $15.15 for 10, which is over $1.50 each...
edit: This thread supports that 90467-07146 is the correct part, from the diagram. When I look the dimensions up, my part is 13.7 mm long, and 6.7 mm wide. The other one is 8.2 mm long, and 7 mm wide, which is likely why they are interchangeable. The Lexus parts guy handed me the 13.7 mm ones based on what I handed him, out of my car. Also, the 13.7 mm ones are less expensive....at one point I would buy the 90467-07146 to have on hand and compare, but I would make it part of a larger order where I'm already paying for shipping (for example I want that left pad in front of the wheel, if I can build up an order, then I would pay $11.95 to ship and start throwing items into the order for the same $11.95)....
p.s. got curious, what then are the dimensions of the ones holding the intake over the radiator, 90467-08155....those are 20.7 mm long, and 8 mm wide, so obviously they would be too big (I got those too lol and the ones in the car are shot)
OK, I was doing my oil change so I found one clip near the bumper missing, so I got out my assortment.
I believe that this part is correct
90467-07146
My picture illustrates the difference. The above actually has a phillips head, but is not a screw at all.
The ones I have also work, and were used prior to my buying the car, which is why I took it out, handed it to the Lexus dealership, and they sold me 3 of what I handed them.
90467-09087-22
Since they flare out, and really aren't the greatest if installed and removed, probably getting knock-offs of 90467-07146 would be the way to go.....my .02
