Rattle inside CD Changer cover/lid
Anybody know if the wood trim separates easily from the plastic backing on the CD changer cover?
I am not sure what is going on here, but it sounds like there is loose s*** inside this wood cover stuck between the black plastic backing and the actual outside wood. Like little pebbles or sand. Giving it a light tap with your finger makes it rattle and so do most bumps in the road. It's literally the only rattle spot in the entire cabin.
Driving me nuts.
Driving me nuts.
I looked to see if i could find anything about taking that apart but could not, it may be that it is clips and an adhesive or glue. So if you are gonna take it apart remove it from the dash and put it in a an oven on a baking sheet for like 2-8 mins on 140-160 then get spackle/paint scrapers and use them to pry it apart carefully.
bklx00
01-31-14 02:29 PM
marcuse
09-04-08 11:44 PM
dantama
02-23-08 09:41 AM
