Front central armrest removal
Lexus LS 430 2002. I need to remove the front central armrest to repair the upholstery which has a hole in it. I have tried to remove the ten screws on the underside of the armrest but nothing moved. Do I have to remove the whole box that contains the upper tray and the lower box which has a cigarette lighter in it.
Yes, removing it seem the easiest way. I'm i the middle of doing that, too, for the same reason. Once you get the two hex bolts out of the bottom of the box and the four bolts and one screw under the rear vent ( the vent pulls out easily from inside the box), you have to just coax the box out from the rear of it forward. I used a stiff putty knife to gently pry it loose all around and then it popped out easily. The hard part I've found is unplugging the little lamp and power outlet to free the box from the console frame. I haven't figured that out yet.
Hope this helps.
You will have to start at the very bottom and pull up the little pad you will see i think two 10m screws. I would do a search on arm rest removal since alot of us already had to remove it including me. You cant just remove the 10 little screws (that would be too easy)..
