Is this oem wiring?
I do know that the can of tire foam is not OEM... ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
I do believe that is not factory wiring. You should be able to see only one wiring harness coming from that firewall access point and running toward the drivers side fender and then dropping down. I think I can barely make that one harness out it your picture...
This is what I have....
