Oil catch can how to with pics
This is my first write up i am missing stuff i know, but i have some pictures as well, so hopefully that will make up for it. You need transmission cooler line, regular radiator hose will not work, the oil will eat through them. I had extra steps because of my strut tower bar.
1. First decide mock up were you want your catch can to be, then take the side plastics and engine bay plastic off so your bay looks like pic 1
2. Take of the pcv vent line install tighten hose on pic 3
3. Place and tighten down hose on pcv return line on intake manifold
4.Install the plastic engine cover with L emblem on it
5. Run the lines to your catch can put on and tighten down
6. Install other engine bay plastics
1.Engine bay with all your plastics removed
Catch can mocked up so i can measure the length of the line needed.
2. This connects to the outlet port on the catch can
You can see a little bit of burnt on residue from the blow by
3.This connects to the hose that goes to the inlet port of the catch can
All done
All done
Nice clean installation. I like the strut brace installation.
A concern that I would have, would be the physics of liquid in a confined space... The fluid will seek the lowest level, which appears to be the section of hose right below the breather hose going to the CAI. It may be that the volume of oil will be so low, that it will be carried back to the can without an issue, but it's possible that the oil, what ever the amount, may settle in those lines..
Just something to think about.
Very valid point did not think of that if the oil is in the air as droplets though wouldnt it get carried to the catch can were it would get caught in the baffles or would it go through the hose and stay at the lowest point? If its gonna go to the lowest point then i will just route the hoses over that cai hose and that should solve the problem correct?
Since you already mounted the catch can, I would at this point leave it as is and monitor the system for the next 1000 miles or so. As I stated earlier, the amount of oil may be insignificant over all, and in the end you'll have a cleaner engine anyway with what you've installed.
Hope this all made sense.
Ezz4001
02-03-18 10:51 AM
Ronstitt
07-01-16 05:24 AM
Fern
RX - 1st Gen (1999-2003)
53
02-12-16 10:24 AM
mikevanle
01-18-07 07:12 PM
