Having trouble getting the steering column cover off
As my steering wheel is stuck at its lowest position, I tried to do a fix that I have seen many here have done. I removed the three screws holding the steering column cover in place and tried to open up the lower cover. However, I couldn't seem to get the cover off despite using quite a bit of force, it seems like its clipped together tight with the upper cover. Is there any trick to getting the lower cover off? Thanks for any advice!
Jabberwock (02-03-18)
Just probably needs a litte bit more force. Once it comes apart just needs to be wiggled out in place. Also be careful with the bottom piece, mine split a little bit where you can see in the above pic to the right/left of that metal tab.
