Hood still isn't done, took a break and to be honest I'm a little discouraged at the moment. I body filled all the dings but I can still feel them. I'm going to spend the extra 50 bucks and spray some high build primer so I can tell what needs work.
Take a break. Get your thoughts together and come back to it in a few days. Do it right the first time and you'll be quite satisfied with the results.
Yeah, I just sprayed degreaser and used a pressure washer.
So the hood is done and that is about all I can say lol. I will be getting it professionally done later. My body work and the hood had too many disagreements.
Got the hood wetsanded with 1500 grit, looks like it will level out decent. At least the orange peel is gone. I wont know how it look until I do the finer grits and compound+polish. So it wasn't a total failure.
you'll get it right.. A little buffing will go a long way.. Nice job so far.
Thanks. The hose I was using to keep the floor wet is very old and with the nozzle off it split and sprayed water everywhere lol. I can't be mad though. I polished out a section, it is acceptable for now. Got a quote from a friend to get it fixed later. Got the gaps and headlights massaged. Passenger headlight need to be pulled apart and resealed. My fault since I tried to reuse the original gasket.
