2006 Lexus LS 430 - I started hearing a rattling noise around the pulleys. What can this be? my gauges are fine . Temp on motor is fine. Coolant is fine.
The LS430 has 2 sets of pulleys - one set driven by the timing belt, and the other by the serpentine belt.
I would suggest to start your troubleshooting with the easier one - the serpentine belt. Remove the belt (see sketches below) and rotate each of the pulleys by hand.
I'm prepping to do the timing belt on my 2005 soon, and the idler pulley for the serpentine belt squeaks a little when the engine is cold. After a few minutes it does quiet down, but it will definitely be replaced when I do the timing belt, along with the serpentine belt.
