Does my motor sound normal to you?
I took a quick video . https://www.youtube.com/watch?v=pNztYYQB7lE&feature=youtu.be
Sound is coming from right side of engine. Youtube made the audio a bit funky but its the higher pitch, almost pneumatic sound, like a chugging sound. Does this sound normal to other owners?
I just purchased this 05 LS430 with 101k miles.. The shop that did the timing belt at around 95k miles is sketchy and I plan on just having it redone (they didn't even do the water pump..) So this could be in relation to that, just odd that its definitely focused on the right side near the cylinder bank.
I don't hear anything highly disturbing. I'll have to try and record mine to make a comparison.
As far as the timing belt, Lexus calls out to replace the timing belt only at 90K miles or 9 years only. They mention nothing about the water pump, idlers, serpentine belt, tensioner, etc. needing replacement. Many owners do decide to replace those items anyway at the same time in order to save on labor cost since it is relatively easy to change those other parts...
I took a quick video . https://www.youtube.com/watch?v=pNzt...ature=youtu.be
P0455 Evaporative Control System Leak Detected (gross Leak)
First relevant thread I found with the same code: Link
End result with that guy was he had a disconnected egr valve.
I was able to reset the code and make it not display after a restart. I'm thinking in my case since I know it just had a timing belt done, by a somewhat sketchy shop.. I called to verify timing belt change, first guy told me no they just checked and advised to get one, next time I called the owner answered and said that they had found a record of them in fact actually doing the TB. Even weirder.. I had a post a few days ago about an LS 430 I was considering buying, which is this one. Link The seller appeared to have lied about the record of the timing belt.
The seller possibly got the car back, noticed a botched job, the shady shop wouldn't stand behind their work, decided to sell and I now have it LOL.
I've owned an LS430 before, a 2002 and a can't EXACTLY remember the way it sounded.. but as soon as I heard this one I thought it was a bit off. I think that off sound coupled with this error code + the fact there is some weirdness going on with the shop/previous owner about the timing belt means its gonna need a new TB at minimum.
While I'm at it.. any 100k+ mile owners get their engine mounts replace? If so was it worth it? If I am going to have it in the shop for a new TB service I'm thinking of doing the mounts too. That along with a fresh alignment and balance and she should be fit to cruise for awhile.
Interesting you say that. Less than an hour from my original post, during my commute home, I noticed the CEL and VSC lights on. Car was acting running and shifting fine so I got it home and pulled the OBD2 reading:
Just curious, is the $600 incl. the parts? I have OE mounts plus the trans mount, but I am early, I bought them when I had a 20% eBay coupon (this has been happening more and more and yesterday was only 15%), but the tech showed me my car on the lift last year and said here are your mounts and your trans mount, you don't need these replaced (wouldn't you know the dealer said I do I bet they didn't even look). I'm at 103k so I figure this will be a while...
Bayliner
12
08-29-13 02:29 PM
