HELP! Lexus Ls430 front driver seat removal
Looking at the manual, looks like you need to remove the four covers that are on top of the bolts. Then remove the seat belt anchor cover cap and bolt. Then unbolt the four bolts that hold the seat to the floor. Disconnect the battery first, and there will be a few plugs underneath for the seat motors/cooler/heat. You might have to raise the seat as high as it will go and go back and forth to access all four bolts.
NinetyFour (05-05-18)
ahero4all
SC- 1st Gen (1992-2000)
07-01-18 07:33 PM
