speaker reccomenations
So all of the speakers on the right side of my car decided to die on me. I decided that I'll replace all of the speakers to get it over with. I'd like to keep my factory amp though. Can anyone recommend some tweeters, door speakers, etc. that don't sound like garbage and are affordable?
Again, I don't know if this is physically possible to do and if the connectors are the same, or if there's enough 'slack' in the wiring harnesses, etc, but that's a good starting point I think. Others who have replaced their amps should be able to chime in and provide info on the connectors, where the amp is (I think the trunk), etc, etc.
If the signal wires are pinched and shorted together, your speaker will not receive any signal to reproduce sound. Since you mentioned that the entire right side is out, the pinch-point is near the amplifier, or the right channel circuit in your amp may be defective.
Which year model is your LS430? I can dig up some diagrams for you to troubleshoot.
Update: turned on my radio today and discovered everything was okay, switched to BT and the problem came back. turns out my aux cord was a bit loose in my BT. I'm stupid.
Hey, we all got to exercise our electronic gremlin troubleshooting logic (thanks LX430inDE!)
and you saved spending $$$'s on speakers. When the subwoofer goes, try www.crutchfield.com
Hey, Caverman, you forgot to mention your write-up on how to repair the subwoofer without removing the back seat...
https://www.clublexus.com/forums/ls-...t-removal.html
caverman (05-07-18)
Saiji
16
09-19-06 01:16 PM
