Common for uz series motors to have crystallized coolant.
Old 05-14-18, 07:48 PM
05ls430518
05ls430518's Avatar
Default Common for uz series motors to have crystallized coolant.
I was reading 2k's t belt thread and saw the crusty coolant on his water pump and was wondering if thats a common thing with the uz motors. My friend just did a timing belt on a tundra with the 2uz and it had a lot of that crystalized coolant see pics below
my question is is it a common thing for the uz series motors to have the coolant crystallize like that? Also what causes it
Last edited by 05ls430518; 05-14-18 at 08:49 PM. Reason: I am stupid and didnt spell check
Old 05-14-18, 08:11 PM
MedicalDoc
MedicalDoc's Avatar
It's not the motor, it's the coolant. It happens in any engine.
Old 05-14-18, 09:18 PM
Gronemus
Gronemus's Avatar
That looks like a lot of coolant that escaped out of the water pump's weep hole. How many miles were on that water pump???
Old 05-14-18, 09:38 PM
05ls430518
05ls430518's Avatar
The motor came from LKQ the customer previous motor blew up from lack of maintenance. LKQ said there was 126,000 on the motor. I doubt the water pump was ever changed judging by the timing belts condition.
Old 05-15-18, 04:57 AM
2KHarrier
2KHarrier's Avatar
I have to believe there's more than 126K on that engine. That belt looks like it's been on there for close to 200K.. All the ancillaries are covered in rust.. Does LKQ store engines outside, or are they located next to a salt factory??
Old 05-15-18, 05:50 AM
05ls430518
05ls430518's Avatar
Thats what my friend said he thinks the motor was stored outside he hasnt had the chance to start the truck up yet. He is worried that when he starts it up its gonna light up like a x-mas tree because a bunch of sensors are bad, or blow up. On a side not this was the only motor available, apparently the 2uz with vvti are exceptionally hard to come by.
Old 05-15-18, 04:20 PM
Davidsofia
Davidsofia's Avatar
The crystals are from the additives they add to the glycol. They are corrosion inhibitor chemicals to pass I ate the aluminum in the block and the radiators. If you happen to spill a little the ethylene glycol, it wiill eventually evaporate, and the leftover salts added, will remain as crystals.
Old 05-15-18, 04:51 PM
05ls430518
05ls430518's Avatar
Oh cool man thank you for sharing your knowledge
Old 06-22-19, 06:36 AM
samsonn25
samsonn25's Avatar
I have 242k on my 07 gs450h with original pink coolant, original waterpump, original brake fluid.
Plugs changed at 132k.
Old 06-24-19, 08:53 AM
NetG
NetG's Avatar
definitly due to lack of maintenance, nothing to do with the engine. I've never seen a 120k belt look THAT bad though, I've seen a motor with about 220k that had a belt that cracked that badly. That's definitly a leaking pump and looks more like it's leaking from everywhere including aroud the pully which only happens after being used through multiple belt changes...I've had the seal between the pump and the block leak when I used a water pump twice and saw it when the second belt was due but it wasn't anything like that, just a little wet on the bottom. It takes a while for coolant to crystalize too. I guess it's possible that's all 126k but that seriously looks to have far more miles than that, imo.
Old 06-24-19, 08:56 AM
NetG
NetG's Avatar
Probably need to have the chain inspected, they're usually good for 190-200k then they start getting some sag. Had to replace my 240sx's chain guides and tensioner at 190, very worn. And you should change all of that you listed, WAY overdue...plugs too, usually every 30k actually, wires every 60k...and color doesn't mean anything. Also your tranny fluid is actually only good for 100k despite "lifetime" claims of the dealership
jsferra
10-11-23 10:09 PM
CEO714
08-14-14 06:11 AM
Peker
07-21-14 01:44 PM
671gs
11-18-12 03:22 PM
jcolegrove
13
10-11-06 02:50 PM
Quick Reply: Common for uz series motors to have crystallized coolant.
