Gyz plzz help ☹️ - vibrations
Guys plzz help ; i have a small cyclic vibration which comes and goes every half a second ; i can feel it in my driver’s seat
i changed every thing:
injectors
plugs
coils
oxygen sensors
engine mount
MAF
Throttle
injectors
plugs
coils
oxygen sensors
engine mount
MAF
Throttle
Tires out of balance? Serpentine belt coming apart? If you're sure it's in the engine, do a compression test and verify the health of the engine. Should be fairly equal in all 8 cylinders and somewhere above 170 PSI.
i feel nothing when the car is at motion ;
it only does when the car is at the parking
engine mounts and transmission mount are already changed
You're not getting a CEL? If you have an OBD II scanner with Live data capabilities, see what the Short Term Fuel Trim looks like while the engine is idling after reaching operating temperature. Fuel trim should be between -3.0 and +3.0 and will cycle as the car is running.
You might want to go back and retrace all the work you did to ensure you haven't left something loose, or not correctly connected. Check any grounds that may have been disconnected.
Oh, by the way... My wife and I visited Ferrari World a few years ago.. Had a great time there. We were vacationing in Dubai, and took a trip down to Abu Dhabi to see the Park. Would love to get back over there some day...
Let us know what you find
Check your intake hoses etc. Are their connections tight? Any rips, or leaks?
Just did mine. At idle, was getting the occasional vibration in shift lever and steering wheel. The old motor mounts didn't look that bad (rubber was starting to separate from metal) but the trans mount was pretty worn. Now, no more vibrations at idle. The car also feels smoother overall.
vinny186
11-23-06 11:18 AM
hyperopt
09-07-04 09:16 PM
