Amp bypass question
Since my OEM mark Levinson amp is going out...
cutting out at high volumes and sub going on when it wants
I wanted to do a amp bypass with a low watt channel amp maybe a 5.
question is can I do the bypass with a ml system or it only works with a non ml system.
From my research it won't work on an ML system. I never did find out for sure on a Pioneer if it would work or if you'd lose the volume control.
Technique
09-05-06 04:00 PM
