04 ls430. crank no start.
Something is exacerbating a voltage spike (possible internal short), I see it at my shop constantly. Not particularly on LS cars (I see ZERO), but a pump is a pump and is not particular to a make.
wow. Oh okay. Yes I will order a fuel pump and I will keep you guys updated!
Thank you for the help sir👍👍👍
I had a similar issue about a year ago. The fuel pump was bad. Try ordering 2 fuel pump from Amazon but they don't see to fit. I ended up just buying the whole fuel pump unit used from eBay and that resolved the issue of not starting
Sorry guys. Just been busy with work and what not. But good news I have bought the Delphi fuel pump and will be installing it this weekend! Fingers cross!
Thanks to all of your guys chimeing in and helping me out!! I appreciate it a lot. Many thanks.
Alright guys more bad news. Ahhh man so I checked plugs. It’s not wet. White though. I replaced the fuel pump (Delphi) still it cranks but no start. No codes.
for maybe like a split sec like a millisecond I thought it was about to start like I seen the rpm needle like move up like it was trying to but it just died. I hope my mind isn’t playing games with me due to fuel pump replacement lol
When you say you thought it was about to start for a split second, was that strictly because of the tach needle moving a little? Or did it also sound like it was about to fire up when the needle jumped?
Did you check the plugs after trying to start it? Or after the car has been sitting for a few days? And white plugs? Like, how white? And do all of the plugs look the same?
I checked just now actually. I just checked one for now. The most easiest to get to. It was pretty white.
I can check the rest tomrrow.
Thanks for the help
Do you have a TechStream? If not, this might be a great time to get one. It may be something related to the theft ECU/immobilizer.
