No A/C lights
Fixed. Replacement bulbs did the trick. I'm not sure what caused 5 bulbs to go out at the same time, but getting new OEM ones did the trick. Again, hat's off to Bell Lexus for getting all of these for me.
And again, Bell Lexus is the only business I will buy my OEM parts from. They are great with their prices and quick to respond to part inquiries such as this one.
https://www.ebay.com/str/belllexusnorthscottsdale
As for pricing, every part Bell sells is only barely more expensive than parts.com. Bell's price for a timing belt kit for our cars, which includes 6 components, is $405.31. I searched all those part #s and added up the prices and came up with a total price of $394.53 on parts.com. The price difference between parts in the $20-$40 range is only like $1-$2. Again, not much difference and probably not enough savings to persuade you to switch sources. If nothing else, keep them in mind if you ever have to buy something closer to the $1,000 range as the savings would be proportionally larger.
For anyone in the future who is searching for bulb part numbers, here you go. This information is direct from Bell Lexus in AZ.
For the HVAC control panel; 90010-03046 BULB, W/CAP 4 total, $5.26 each
For the temperature control switches on either side of the dash; 90010-03043 BULB, W/CAP 2 total $5.26
For the sunshade control switch; 90010-01070 BULB, W/CAP 1 total $4.78
For the seat heat/cool; 90010-01071 BULB, W/CAP 1 total $5.26
My local Lexus dealer was NO help at all for these. Google is also no help as these seem to be seldom replaced. From looking at the ones I removed, they are almost identical, though the bases are either gray, white, or a orange/rust color. While the bases are the same/similar, the difference I believe is in the wattage of the bulbs themselves.
I'm going to return the HVAC panel I ordered and eat the few bucks it will cost for shipping. Hopefully this will be helpful to someone in the future. And again, Bell Lexus is the only business I will buy my OEM parts from. They are great with their prices and quick to respond to part inquiries such as this one.
I really only need to replace the heated seat **** light and don't mind if it's too bright/uneven. I can't find this type of bulb on their site.
For LED style, they are usually called "Neo3". Incandescent versions are usually called "wedge t3".
I ordered the 3mm and 4mm ones.
https://www.superbrightleds.com/more...-led/221/7740/
Be advised that to me, they were junk. Absolute garbage. The plastic base was so soft, it distorts easily. I was surprised by all of the positive reviews because it is a real lackluster product.
I went ahead and ordered some NEO T4.2 from ebay per the recommendation of another thread on here. They seem to have a slightly different material for the base, so hopefully htey work out well. (They were only $5.40 shipped for 10)
It looks like you can actually order 10 from china for under $2 shipped.... not quite sure how the economics of that work, but it's there.
Also I'm 90% sure the footwell lights are it's own separate component. Probably soldered on LED's if I'm not mistaken. I would be mildly suprised if they used those twist-on style bulbs down there.
Most all of the switch bulbs are 3mm. We carry them here for 99 cents each. Reuse your plastic base.
http://www.taninautoelectronix.com/3...mm60or80ma.htm
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
262-456-4147
I forget exactly what size, but i THINK they are 3mm since they are called Neo3's. Also had to get Neo2's for the window adjuster switch and parking sensors switch.
you are not the only one!
Glad the information was beneficial to you!
Carfreak70
SC- 1st Gen (1992-2000)
08-31-08 03:01 PM
