If this Carfax is accurate, the timing belt wasn't changed until 228k.
https://www.autotrader.com/car-news/...81474979853589
Saw the Doug kinda douchey Demuro (sorry--the stupid doug scores annoy me) with this 495,000 mile LS430.
It's still on the second timing belt, at 500,000 miles. I went to look at Lexus service history but that site is always a PITA to navigate.
Can that even be? 228k on a timing belt? And then another 270k on the next one?
If it's carfax I wouldn't put too much faith in it. My wife's and my BMW were purchased new and none of the services performed at the dealership are on it. As in not one. Services performed (state inspections) by muffler shops are on it. Unfortunately if it were me and I were buying, I want paper receipts. Bulky but imho hard to forge.
Then, on my 1998 Nissan Maxima, EVERY SERVICE FROM 2000 TO 2016 is on the carfax, dealer and muffler shops.
Who knows how/why it works. There has been speculation on this forum that 90k is half of how long a timing belt was designed to go....
About Doug, he is from my area but I don't understand why his accent is the way it is. He seems like an ok person but his sentence intonation is very odd.
Here's the car's Lexus Service History. One timing belt noted, which happened to be done at an outside repair facility. Loads of brake work, however and lots of gaps, which no doubt means the car was serviced outside of the dealership.
I tell you what, though. There's really nothing abnormal in the info here. Just another testament to the ridiculous reliability of this car...
SERVICE HISTORY FOR: 2003 LS430
VIN: JTHBN30F430119513
REPAIR# 0085889
REPORTED BY: Lexus of Lincoln
SERVICE: CHARGED BATTERY
DESCRIPTION: CHARGED BATTERY ~ ~BATTERY R&R ~ ~
SERVICE: CHECK HOOD LATCH
DESCRIPTION: CHECK HOOD LATCH ~ ~HOOD DOESN'T CLOSE ~ ~
SERVICE: REPLACE HOOD LATCH CABLE
DESCRIPTION: REPLACE HOOD LATCH CABLE ~ ~REPLACE HOOD LATCH CABLE ASSY ~ ~
REPAIR# 0083556
SERVICE: PRE-OWNED RE-INSPECTION FROM ANOTHER DEALER
DESCRIPTION: PRE-OWNED RE-INSPECTION FROM ANOTHER DEALER ~ ~PRE-OWNED RE-INSPECTION FROM ANOTHER DEALER ~ ~PRE-OWNED INSPECTION
REPAIR# 0080279
SERVICE: COMPLIMENTARY WORLD CLASS MULTI-POINT INSPECTION
DESCRIPTION: COMPLIMENTARY WORLD CLASS MULTI-POINT INSPECTION ~ ~COMPLIMENTARY WORLD CLASS MULTI-POINT INSPECTION ~ ~
SERVICE: REPLACED THE RIGHT FRONT WHEEL BEARING
DESCRIPTION: REPLACED THE RIGHT FRONT WHEEL BEARING ~ ~CS THE RIGHT FRONT WHEEL BEARING MIGHT BE BAD ~ ~ ~ ~459943 BEARING REMOVED AND REPLACED THE FAILED RIGHT FRONT WHEEL BEARING
REPAIR# 0078273
SERVICE: REPLACED USED ALTERNATOR LKQ
DESCRIPTION: REPLACED USED ALTERNATOR LKQ ~ ~CS THE HEADLAMP LEVELING AND BATTERY WARNING LIGHTS ARE ON ~ ~ ~ ~451117 INSTALLED ALTERNATOR(USED ALTERNATOR)
REPAIR# 0078128
SERVICE: REPLACED CHARCOAL CANISTER
DESCRIPTION: REPLACED CHARCOAL CANISTER ~ ~CHECK ENGINE/SERVICE ENGINE LAMP ( CHECK FOR STORED FAULT CODESUSING ONBOARD SYTEM ANALYZER WITH VEHICLES FUEL&EMISSIONS SYTEMS. INCLUDE BASIC CODE DIAGNOSIS, FUEL SYSTEM TEST,ENGINE PERFORMANCE TESTEVAP EM... READ MORE
REPAIR# 0077962
SERVICE:
DESCRIPTION: CHECK ENGINE/SERVICE ENGINE LAMP ( CHECK FOR STORED FAULT CODESUSING ONBOARD SYTEM ANALYZER WITH V ~ ~CHECK ENGINE/SERVICE ENGINE LAMP ( CHECK FOR STORED FAULT CODESUSING ONBOARD SYTEM ANALYZER WITH VEHICLES FUEL&EMISSIONS SYTEMS. INCLU... READ MORE
SERVICE: REPLACE ALL SPARK PLUGS.
SERVICE: REPLACE PIGTAIL AND BULBS
DESCRIPTION: REPLACE PIGTAIL AND BULBS ~ ~REPLACE PIGTAIL FOR TAIL LIGHT ~ ~ ~ ~449970 REPLACED PIGTAIL. FOUND THE SOCKETS TO BE BURNT AND ALSO COULD NOT INSTALL NEW PIGTAIL WITHOUT REMOVING LAMP AND FILING DOWN THE BURNT FEMALE END. REMOVED AND FILED T... READ MORE
REPAIR# 0077265
SERVICE: REPLACEMENT OF TAILLAMP BULB ASSEMBLY
DESCRIPTION: REPLACEMENT OF TAILLAMP BULB ASSEMBLY ~ ~REPLACEMENT OF TAILLAMP BULB ASSEMBLY ~ ~
REPAIR# 0076088
SERVICE: REPLACED WHEEL LINER
DESCRIPTION: REPLACED WHEEL LINER ~ ~CS THE BRAKES ARE MAKING NOISE AGAIN ~ ~ ~ ~439859 NOISE TECHNICIAN FOUND THIS NOISE TO BE COMING FROM THE TIRE RUBBING AGAINST THE DAMAGED WHEEL LINER. THE NOISE IS ONLY PRESENT IN REVERSE WITH THE WHEEL COMPLETELY ... READ MORE
REPAIR# 0309502
REPORTED BY: Lexus of Omaha
SERVICE: R&R RADIATOR ASSY
DESCRIPTION: R&R RADIATOR ASSY ~ ~CUSTOMER STATES CAR IS RUNNING HOT. VISIBLE SIGNS OF LEAK UNDER HOOD. PRIOR HAD 2 COOLING FANS INSTALLED BY LEXUS OF LINCOLN. INSPECT AND ADVISE ~ ~ ~ ~431344 CUSTOMER STATES: FOUND UPPER RADIATOR TANK CRACKED. INST... READ MORE
REPAIR# 0074303
SERVICE: BRAKES OPERATING AS NORMAL
DESCRIPTION: BRAKES OPERATING AS NORMAL ~ ~C/S THE VEHICLE IS STILL MAKING BRAKE NOISE FROM THE FRONT ~ ~
REPAIR# 0073390
SERVICE: PERFORM FRONT BRAKE RECON
DESCRIPTION: PERFORM FRONT BRAKE RECON ~ ~C/S THAT THE BRAKES STILL MAKE NOISE AT TIMES ~ ~ ~ ~426301 NOISE TECHNICIAN TEST DROVE THE CAR AND WAS UNABLE TO HEAR THE NOISE THAT THE GUEST HAS CONCERNS OF. GUEST HAD MENTIONED THAT IT IS INTERMITTENT BUT AP... READ MORE
SERVICE: VERIFIED TIRE BALANCE
DESCRIPTION: VERIFIED TIRE BALANCE ~ ~C/S THAT THE TIRES ARE A BIT LOUD ~ ~ ~ ~426301 TIRES THE TIRES SOUND OK, DID NOT HEAR ANY ABNORMAL TIRE NOISE, GIVEN THE BRAND OF TIRE PLACED ON THE VEHICLE
REPAIR# 0072649
SERVICE: MOUNT/BALANCE 4 CONVENTIONAL TIRES ONLY.
DESCRIPTION: MOUNT/BALANCE 4 CONVENTIONAL TIRES ONLY. ~ ~MOUNT/BALANCE 4 CONVENTIONAL TIRES ONLY. ~ ~ ~ ~422739 CTM4 MOUNT AND BALANCE OF FOUR TIRES COMPLETED
SERVICE: REPLACE FRONT AND REAR BRAKE PAD HARDWARE
DESCRIPTION: REPLACE FRONT AND REAR BRAKE PAD HARDWARE ~ ~C/S THAT THERE IS A BRAKE NOSIE AT TIMES ~ ~ ~ ~422739 NOISE TECHNCIAN WAS ABLE TO DUPLICATE THIS BRAKE NOISE LESS THAN 5% OF THE STOPS. COULD ONLY BE DUPLICATED WITH A FAIRLY HEAVY BRAKE APPLICA... READ MORE
REPAIR# 0303664
SERVICE: INTERIOR LEATHER & VINYL REPAIR BY AIS
DESCRIPTION: INTERIOR LEATHER & VINYL REPAIR BY AIS ~ ~INTERIOR LEATHER & VINYL REPAIR BY AIS ~ ~
REPAIR# 0303319
SERVICE: BATTERY R&R
DESCRIPTION: BATTERY R&R ~ ~BATTERY LOAD TEST AND INSPECT **REPLACE IF NEEDED** ~ ~ ~ ~420995 BATTERY FAILED TESTING, INSTALLED NEW BATTERY
SERVICE: CANNOT LOCATE EAR PIECE
DESCRIPTION: CANNOT LOCATE EAR PIECE ~ ~CUST DROPPED EAR PIECE ON DRIVERS SEAT NEXT TO CENTER CONSOLE ~ ~ ~ ~420995 UNABLE TO FIND EAR PIECE
REPAIR# 0070564
SERVICE:
DESCRIPTION: WASH & DRY VEHICLE ( WEATHER PERMITTING ), CLEAN GLASS IN/OUT, VAC INSIDE OF VEHICLE.WASH & DRY VEHICLE ( WEATHER PERMITTING ), CLEAN GLASS IN/OUT, VAC INSIDE OF VEHICLE.COMPLETE 4 WHEEL ALIGNMENTFOR ALL MODELS ( INCLUDING ADJUSTMENT OF TOE IN, TOE OUT, CASTER, CAMBER ~ ~COMPLETE 4 WHEEL ALIGNMENTFOR ALL MODELS ( INCLUDING ADJUSTMENT OF TOE IN, TOE OUT, CASTER, CAMBER, SAI ANGLE, REAR THRUST ANGLE). ~ ~VEHI... READ MOREWASH & DRY VEHICLE ( WEATHER PERMITTING ), CLEAN GLASS IN/OUT, VAC INSIDE OF VEHICLE.
SERVICE: RECOMMEND CONTROL ARM BUSHINGS
DESCRIPTION: RECOMMEND CONTROL ARM BUSHINGS ~ ~CHECK FRONT AND REAR SUSPENSION FOR LOOSE PARTS ~ ~ ~ ~411358 BUSHINGS FOUND THAT THE FRONT LOWER REAR BUSHINGS ARE WEAK AND HAVE TOO MUCH PLAY IN THEM. ALIGNMENT INSPECTED FOUND THAT THE FRONT CASTER WAS O... READ MORE
SERVICE: RECOMMEND FRONT AND REAR BRAKES
DESCRIPTION: RECOMMEND FRONT AND REAR BRAKES ~ ~CHECK BRAKES, VIBRATION WHEN APPLYING BRAKES ~ ~ ~ ~411358 FBP FRONT BRAKES ARE WHERE THE VIBRATION/PULSATION IS COMING FROM. REPLACED THE FRONT BRAKE PADS, MACHINED THE ROTORS
SERVICE: REPLACE CONTROL ARM BUSHINGS
DESCRIPTION: REPLACE CONTROL ARM BUSHINGS ~ ~REPLACE CONTROL ARM BUSHINGS ~ ~ ~ ~411358 BUSHING TECHNICIAN FOUND THAT THE FRONT LOWER REAR CONTROL ARM BUSHING WERE WORN AND HAVE TOO MUCH PLAY. REPLACED THE BUSHINGS AND THE BRACKET FOR THE BUSHINGS WIOTH... READ MORE
SERVICE: REPLACE FRONT BRAKE PADS AND MACHINE FRONT ROTORS.
DESCRIPTION: REPLACE FRONT BRAKE PADS AND MACHINE FRONT ROTORS. ~ ~REPLACE FRONT BRAKE PADS AND MACHINE FRONT ROTORS. ~ ~PADS BELOW SPECS, ROTORS OUT OF ROUND ~ ~411358 FBP REMOVED AND REPLACED THE FRONT BRAKE PADS, AND MACHINED THE ROTORS
SERVICE: REPLACE REAR BRAKE PADS AND MACHINE REAR ROTORS.
DESCRIPTION: REPLACE REAR BRAKE PADS AND MACHINE REAR ROTORS. ~ ~REPLACE REAR BRAKE PADS AND MACHINE REAR ROTORS. ~ ~PADS BELOW SPECS, ROTOR RUNOUT OUT OF SPEC ~ ~411358 RBP REMOVED AND REPLACED THE REAR BRAKE PADS. THE RIGHT REAR CALIPER BOLT WAS FROZE... READ MORE
SERVICE: REPLACED CLIPS
DESCRIPTION: REPLACED CLIPS ~ ~CHECK UNDER COVER FOR MISSING CLIPS ~ ~ ~ ~411358 BOLTS REPLACED THE MISSING BOLTS ARE THE INCORRECT BOLTS WITH 9 NEW ONES
SERVICE: REPLACEMENT OF HEADLAMP BULB
DESCRIPTION: REPLACEMENT OF HEADLAMP BULB ~ ~REPLACEMENT OF HEADLAMP BULB ~ ~ ~ ~411358 BULB REPLACED THE RF FRONT HEAD LAMP BULB HIGH BEAM. BULB WAS OPERATING BUT BURNED SO THAT THE TOP HALF OF THE BULB WASN'T ILLUMINATING AS DESIGNED. REMOVED AND REPL... READ MORE
SERVICE: ROAD TEST VEHICLE
DESCRIPTION: COMPLETE 4 WHEEL ALIGNMENTFOR ALL MODELS ( INCLUDING ADJUSTMENT OF TOE IN, TOE OUT, CASTER, CAMBER
REPAIR# 0068651
DESCRIPTION: REPLACEMENT OF HEADLAMP BULB ~ ~REPLACEMENT OF HEADLAMP BULB ~ ~ ~ ~400938 REPLACED DRIVER SIDE HEADLAMP BULB
REPAIR# 0066324
SERVICE: REPLACE LEFT FRONT WHEEL BEARING
DESCRIPTION: REPLACE LEFT FRONT WHEEL BEARING ~ ~REPLACE SOP WHEEL BEARING ~ ~ ~ ~388210 WHEEL BEARING REPLACED LEFT FRONT WHEEL BEARING. BRAKES - ALL AT 4-5MM. BOTH FRONT STRUTS STARTING TO LEAK. RT SIDE WORSE. BOTH FRONT STRUTS AND MOUNTS INSTALLED WI... READ MORE
REPAIR# 0065135
SERVICE: REPLACE COOLING FAN MOTOR
DESCRIPTION: REPLACE COOLING FAN MOTOR ~ ~C/S THAT AT IDLE OR LOW SPEEDS THE AC WILL NOT COOL, AT HIGHWAY SPEED COOLS FINE. CHECK AND ADVISE ~ ~ ~ ~382047 CS NO AC AND OVERHEATING AT IDLE CS THAT THE CAR WAS OVERHEATING AT AN IDLE AND AC WOULD NOT BLOW... READ MORE
REPAIR# 0063328
DESCRIPTION: REPLACE COOLING FAN MOTOR ~ ~C/S REPLACE DRIVERS SIDE COOLING FAN. SOP. ~ ~ ~ ~371969 COOLING FAN MOTOR REPLACED COOLING FAN MOTOR ON DRIVERS SIDE FOR NOISE AND FILLED COOLANT. COOLANT IS GREEN
REPAIR# 0062750
DESCRIPTION: REPLACEMENT OF TAILLAMP BULB ASSEMBLY ~ ~C/S THAT THE TAIL LAMP WARNING IS ON AND THE HIGH MOUNT BRAKE LAMP IS OUT ~ ~ ~ ~368687 BULBREPLACED 3RD BRAKE LIGHT BULB.
REPAIR# 0060902
SERVICE: REPLACE DRIVER'S SIDE VALVE COVER GASKET
DESCRIPTION: REPLACE DRIVER'S SIDE VALVE COVER GASKET ~ ~REPLACE DRIVER'S SIDE VALVE COVER GASKET ~ ~ ~ ~358295 VALVE COVER GASKET REPLACED LEFT VALVE COVER GASKET.
SERVICE: REPLACE OIL PAN GASKET AND O-RIN
DESCRIPTION: REPLACE OIL PAN GASKET AND O-RIN ~ ~REPLACE OIL PAN GASKET AND DIPSTICK O-RING ~ ~ ~ ~358295 OIL PAN RESEAL OIL PAN AND DIPSTICK TUBE.
SERVICE: SEE LINES B AND C
DESCRIPTION: SEE LINES B AND C ~ ~C/S THERE IS AN OIL LEAK ~ ~ ~ ~358295 CHECK OIL LEAK CHECK OIL LEAK. OIL PAN, DIPSTICK, AND LEFT VALVE COVER.
REPAIR# 0060497
SERVICE: COULD NOT DUPLICATE, NO LIGHTS OUT
DESCRIPTION: COULD NOT DUPLICATE, NO LIGHTS OUT ~ ~REPLACEMENT OF TAILLAMP BULB ASSEMBLY
REPAIR# 0059105
REPAIR# 0058580
SERVICE: CUSTOMER APPRECIATION GIFT CERTIFICATE ( 10% OFF ANY MAJOR SCHEDULED MIANTENANCE
DESCRIPTION:
SERVICE: LEFT FRONT TIRE HAS INSIDE EDGE CUPPING, SLIGHT RF ALSO
DESCRIPTION: LEFT FRONT TIRE HAS INSIDE EDGE CUPPING, SLIGHT RF ALSO ~ ~C/S THAT IT SOUNDS LIKE THE CAR HAS A BAD FRONT WHEEL BEARING, CHECK AND ADVISE. ~ ~ ~ ~345620 WHEEL BEARING NOISE C/S THAT THERE IS A BAD WHEEL BEARING NOISE, ROTATED TIRES AND NOI... READ MORE
SERVICE: R&R WIPER BLADE INSERTS
DESCRIPTION: R&R WIPER BLADE INSERTS ~ ~R&R WIPER BLADE INSERTS ~ ~ ~ ~345620 WIPER BLADES
REPAIR# 0057364
DESCRIPTION:
SERVICE: REPLACE VVTI GEAR
DESCRIPTION: REPLACE VVTI GEAR ~ ~C/S THAT THEY HAD THE TIMING BELT REPLACED AND IMMEDIATELY AFTER THE ENGINE HAS A DIFFERENT SOUND. (POSSIBLY TENSIONER BEARING). CHECK AND ADVISE ~ ~ ~ ~337517 TAKEN TO INDEPENDENT SHOP FOR T BELT REPLACEMENT. OTHER SHO... READ MORE
REPAIR# 0055948
SERVICE: BALANCE 2 FRONT TIRE / WHEELS.
DESCRIPTION: BALANCE 2 FRONT TIRE / WHEELS. ~ ~CUSTOMER STATES THERE IS A PRETTY BAD SHIMMY SINCE WE DID BRAKES. NOT WHEN BRAKING, BUT JUST WHEN DRIVING. WANTS US TO LOOK AT CLEANING HUB/BACK OF WHEEL ~ ~ ~ ~328147 CLEANED BACK OF WHEELS/HUBS. CHECKED V... READ MORE
REPAIR# 0055747
DESCRIPTION:
DESCRIPTION: REPLACE FRONT BRAKE PADS AND MACHINE FRONT ROTORS. ~ ~REPLACE FRONT BRAKE PADS AND MACHINE FRONT ROTORS. ~ ~PADS BELOW SPECS, ROTORS OUT OF ROUND ~ ~327147 FBP REPLACED THE FRONT BRAKE PADS AND MACHINED THE ROTORS. *ADVISED REPLACMENT OF TH... READ MORE
DESCRIPTION: REPLACE REAR BRAKE PADS AND MACHINE REAR ROTORS. ~ ~REPLACE REAR BRAKE PADS AND MACHINE REAR ROTORS. ~ ~PADS BELOW SPECS, ROTOR RUNOUT OUT OF SPEC ~ ~327147 RBP REPLACED THE REAR BRAKE PADS AND MACHINED THE ROTORS
DESCRIPTION:
SERVICE: WASH & DRY VEHICLE ( WEATHER PERMITTING ), CLEAN GLASS IN/OUT, VAC INSIDE OF VEH
DESCRIPTION:
REPAIR# 0050442
DESCRIPTION: REPLACEMENT OF TAILLAMP BULB ASSEMBLY ~ ~C/S THAT THERE IS A TAIL LIGHT OUT ~ ~ ~ ~291971 REPLACED 2 INCORRECT BULBS AND 2 BURNT BULBS IN THE TAIL LIGHT ASSEMBLY. ONE OF THE INCORRECT BULBS HAS BURNT THE SOCKET OF THE TAIL LIGHT, IT IS REPL... READ MORE
SERVICE: TRANSMISSION FLUID FLUSH-BG
DESCRIPTION: TRANSMISSION FLUID FLUSH-BG ~ ~TRANSMISSION FLUID FLUSH-BG ~ ~ ~ ~291971 FLUID FLUSH BG ATF FLUSH COMPLETE.
REPAIR# 0047647
SERVICE: CABIN AIR FILTER REPLACEMENT (HEPPA ) FILTER OUT POLLEN,BACTERIA,DUST,SOOT, AND
DESCRIPTION: CABIN AIR FILTER REPLACEMENT (HEPPA ) FILTER OUT POLLEN,BACTERIA,DUST,SOOT, AND ~ ~CABIN AIR FILTER REPLACEMENT (HEPPA ) FILTER OUT POLLEN,BACTERIA,DUST,SOOT, AND ODORS. ~ ~ ~ ~274952 REPLACED A/C FILTER
SERVICE: PERFORM 27 POINT INPSECTION
DESCRIPTION: PERFORM 27 POINT INPSECTION ~ ~C/S THEY WOULD LIKE VEHICLE INSPECTED ~ ~ ~ ~274952 BRAKES FRT 7MM, REAR NOW TODAY 10MM, TIRES 6/32"" WITH EDGE WEAR. P/S FLUID VERY DIRTY. BG IND SERVICE DUE. TRANSMISSION FLUID VERY DIRTY. 30K SERVICE DUE AT... READ MORE
SERVICE: REPLACE AIR FILTER
DESCRIPTION: REPLACE AIR FILTER ~ ~REPLACE AIR FILTER ~ ~ ~ ~274952 REPLACED AIR FILTER
DESCRIPTION: REPLACE REAR BRAKE PADS AND MACHINE REAR ROTORS. ~ ~REPLACE REAR BRAKE PADS AND MACHINE REAR ROTORS. ~ ~PADS BELOW SPECS, ROTOR RUNOUT OUT OF SPEC ~ ~274952 REPLACED REAR BRAKES AND TURNED REAR ROTORS
DESCRIPTION: REPLACEMENT OF HEADLAMP BULB ~ ~REPLACEMENT OF HEADLAMP BULB ~ ~ ~ ~274952 REPLACED BULB
DESCRIPTION:
DESCRIPTION:
REPAIR# 0045135
SERVICE: REPLACED CUSTOMERS PARTS
DESCRIPTION: REPLACED CUSTOMERS PARTS ~ ~REPLACE BLOWER MOTOR. CUSTOMER WILL BRING HIS OWN PART
REPAIR# 0204551
SERVICE: 90,000 MILE SERVICE & INSPECTION *PALTINUM PLAN* FOR LS MODELS
DESCRIPTION: 90,000 MILE SERVICE & INSPECTION *PALTINUM PLAN* FOR LS MODELS ~ ~180,000 MILE SERVICE & INSPECTION *PALTINUM PLAN* FOR LS MODELS *NO ROTATION/BALANCE* ~ ~ ~ ~228694 MAINT COMPLETED 180K SERVICE. BRKS 2MM, (WORN INTO SENSORS), TIRES... READ MORE
SERVICE: BALL JOINTS & DUST COVER ISPECT.
DESCRIPTION:
SERVICE: INSPECT BRAKE LINES,PIPES, & HOSES
DESCRIPTION:
SERVICE: INSPECT DRIVE SHAFT BOOTS & RETORQUE DRIVE SHAFT FLANGE BOLT
DESCRIPTION:
SERVICE: INSPECT ENGINE COOLANT ( 05 AND LATER ), REPLACE ENGINE COOLANT 04 & EARLIER.
DESCRIPTION:
SERVICE: INSPECT FUEL LINES & CONNECTIONS INSPECT FUEL TANK BAND, AND
DESCRIPTION:
SERVICE: INSPECT STEERING LINKAGE
DESCRIPTION:
SERVICE: MEASURE THICKNESS OF FRONT BRAKE PADS AND ROTORS
DESCRIPTION:
SERVICE: RECALIBRATE COMPASS
DESCRIPTION: RECALIBRATE COMPASS ~ ~CUSTOMER STATES COMPASS READS WRONG DIRECTION ~ ~ ~ ~228694 RECALIBRATED COMPASS
SERVICE: REPLACE AC HEPPA FILTER ASSEMBLY
DESCRIPTION:
SERVICE: REPLACE BRAKE SYSTEM FLUID
DESCRIPTION:
SERVICE: REPLACE ENGINE OIL, OIL FILTER, DRAIN PLUG GASKET & RESET MAINTENANCE REMINDER L
DESCRIPTION:
SERVICE: ROTATE TIRES ( ALL MODELS EXCEPT IS300 SPORT CROSS / IS250 RWD & IS350 MODELS.
DESCRIPTION:
REPAIR# 0037149
REPAIR# 0189723
DESCRIPTION: REPLACEMENT OF TAILLAMP BULB ASSEMBLY ~ ~TAILLAMP INDICATOR ON AT DASH, CHECK AND ADVISE. LT UPPER TAIL LIGHT BULB REPLACED BUT LIGHT STAYS ON ~ ~ ~ ~188185 WRONG BULB REPLACE TAIL LIGHT BULB LH UPPER OUTSIDE. NOTE BULB SOCKET BROKEN MAY CO... READ MORE
SERVICE: TIRE REPAIR DISMOUNT PATCH TIRE MOUNT & BALANCE.
DESCRIPTION: TIRE REPAIR DISMOUNT PATCH TIRE MOUNT & BALANCE. ~ ~RIGHT FRONT TIRE IS LOOSING AIR ~ ~FORIEGN OBJECT FOUND IN TIRE ~ ~188185 NAIL PLUG PATCH AND REPLACE VALVE STEM RH FRT TIRE COMPLETE
SERVICE: TOUCH UP PAINT
DESCRIPTION: TOUCH UP PAINT ~ ~CUSTOMER REQUEST BOTTLE OF TOUCH UP PAINT ~ ~ ~ ~188185 TOUCH UP PAINT IN ASH TRAY
REPAIR# 0178311
SERVICE: RIGHT FRONT WHEEL BEARING ASSY
DESCRIPTION: RIGHT FRONT WHEEL BEARING ASSY ~ ~*CUSTOMER STATES THERE IS A HUM NOISE FROM RIGHT FRONT WHEN* ~ ~RF WHEEL BEARING. ~ ~157155 RF WHEEL BEARING. REPLACED RF WHEEL BEARING. SLIGHT NOISE STILL FROM LR WHEEL BEARING, EST $751.00.
REPAIR# 0165825
SERVICE: REPLACE STARTER ASSEMBLY , 8 CYLINDER MODEL.
DESCRIPTION: REPLACE STARTER ASSEMBLY , 8 CYLINDER MODEL. ~ ~CUSTOMER STATES VEHICLE WILL NOT START AT TIMES, JUST CLICKS ~ ~INTERNAL FAILURE. ~ ~123893 INTERNAL FAILURE. STARTER REPLACED.
REPAIR# 0162120
SERVICE: CHECK ALL FLUID LEVELS
DESCRIPTION:
SERVICE: DISCOUNT (-$20.80 ).
DESCRIPTION:
SERVICE: INSPECT TIRE PRESSURE, WEAR AND SET PRESSURE.
DESCRIPTION:
SERVICE: OIL & FILTER SERVICE FOR ALL LS400 / LS430 MODELS.
DESCRIPTION: OIL & FILTER SERVICE FOR ALL LS400 / LS430 MODELS. ~ ~OIL & FILTER SERVICE FOR ALL LS400 / LS430 MODELS. ~ ~ ~ ~113831 LOF COMP
DESCRIPTION:
SERVICE: TIRE ROTATION
DESCRIPTION: TIRE ROTATION ~ ~TIRE ROTATION ~ ~ ~ ~113831 ROT COMP F-7/32 R-7/32 FBP-10MM RBP-9MM
SERVICE: WASH & DRY VEHICLE, CLEAN GLASS IN/OUT, VAC INSIDE OF VEHICLE.
DESCRIPTION:
REPAIR# 0160493
SERVICE: REPLACED REAR DIFFERENTIAL DRAIN PLUG GASKET
DESCRIPTION: REPLACED REAR DIFFERENTIAL DRAIN PLUG GASKET ~ ~CUSTOMER STATES THERE IS A LEAK FROM REAR DIFFERENTIAL ~ ~ ~ ~109095 DRAIN DIFFERENTIAL, REPLACE CRUSH GASKET ON DRAIN PLUG, AND REFILL DIFFERENTIAL WITH SYNTHETIC FLUID.
REPAIR# 0157815
SERVICE: 90K MILE SERVICE INSPECTION,""""PLATINUM PLAN"""" FOR LX450/470 BALANCE 2 FRONT
DESCRIPTION: 90K MILE SERVICE INSPECTION,""PLATINUM PLAN"" FOR LX450/470 BALANCE 2 FRONT WHEE ~ ~90K MILE SERVICE INSPECTION,""PLATINUM PLAN"" FOR LX450/470 BALANCE 2 FRONT WHEEL ~ ~ ~ ~100155 90K SERVICE COMPLETE. T-BELT, SERP BELT REPLACED. FBP NEW, R... READ MORE
SERVICE: LUBED SWAY BAR BUSHINGS
DESCRIPTION: LUBED SWAY BAR BUSHINGS ~ ~AT TIMES WHEN GOING OVER BUMPS THERE IS A SQUEAK FROM RIGHT REAR, CAN BE HEAR BY PASS RIDING IN RIGHT REAR POSSITION ~ ~ ~ ~100155 LUBRICATE FRONT AND REAR SWAY BAR BUSHINGS TO START OUT. WILL DRIVE AGAIN.
SERVICE: NEEDS VENT ASSY REPLACED
DESCRIPTION: NEEDS VENT ASSY REPLACED ~ ~AT TIMES CENTER VENT OCCILATOR STICKS AND MAKES NOISE ~ ~ ~ ~100155 RECOMMEND REPLACING VENT WITH OSCILATOR ASSY $580.00.
DESCRIPTION: REPLACE FRONT BRAKE PADS ~ ~REPLACE FRONT BRAKE PADS ~ ~ ~ ~100155 FRONT BRAKE PADS REPLACED.
DESCRIPTION: REPLACE REAR BRAKE PADS ~ ~REPLACE REAR BRAKE PADS ~ ~ ~ ~100156 REAR BRAKE PADS REPLACED.
REPAIR# 0144921
SERVICE: * EXTERIOR DERAIL SPECIAL * (BUFF, POLISH, SEAL.) $129.95
DESCRIPTION: * EXTERIOR DERAIL SPECIAL * (BUFF, POLISH, SEAL.) $129.95 ~ ~* EXTEIROR DETAIL SPECIAL * (BUFF, POLISH, SEAL.) $129.95
DESCRIPTION:
SERVICE: INSPECT BRAKES:LINING,DISC,DRUM FRONTS % REMAINING REARS % REMAINING INSPECT TIR
DESCRIPTION: INSPECT BRAKES:LINING,DISC,DRUM FRONTS % REMAINING REARS % REMAINING INSPECT TIR ~ ~BRAKES SQUEAK WHEN BACKING OUT OF GARAGE, ESPECIALLY WHEN HUMIDITY IS HIGH ~ ~ ~ ~60089 BRAKE THICKNESS F-6.5MM R-6.5MM SANDED NON DIR ECTIONAL FINISH ON OU... READ MORE
DESCRIPTION: OIL & FILTER SERVICE FOR ALL LS400 / LS430 MODELS. ~ ~OIL & FILTER SERVICE FOR ALL LS400 / LS430 MODELS. ~ ~ ~ ~60089 LOF COMP
DESCRIPTION: TIRE ROTATION ~ ~TIRE ROTATION ~ ~ ~ ~60089 TIRE ROTATION COMP
REPAIR# 0142766
SERVICE: 45,000 MILE SERVICE & INSPECTION*PLATINUM PLAN* FOR ALL LS MODEL
DESCRIPTION: 45,000 MILE SERVICE & INSPECTION*PLATINUM PLAN* FOR ALL LS MODEL ~ ~45,000 MILE SERVICE & INSPECTION*PLATINUM PLAN* FOR ALL LS MODEL ~ ~ ~ ~49878 COMPLETE 45K TIRES 7/32 BRKS F-5MM R-6MM
SERVICE: COMB: F.SEAT CUSH ASSY,1-SD
DESCRIPTION:
SERVICE: COMB: FRT SEAT BCK ASSY,1-SD
DESCRIPTION:
SERVICE: COMB: FRT SEAT CUSH CVR,1-SD
DESCRIPTION:
SERVICE: FRONT SEAT ASSY, ONE SIDE
DESCRIPTION: FRONT SEAT ASSY, ONE SIDE ~ ~*CUSOTMER STATES LEFT FRONT SEAT BOTTOM IS BUNCHING UP* ~ ~POOR FIT ~ ~49876 REPLACE LF FRT SEAT COVER LEATHER AND CUSHION
DESCRIPTION: REPLACEMENT OF TAILLAMP BULB ASSEMBLY ~ ~CUSTOMER STATES TAIL LAMP FAILURE LIGHT WAS ON, LEFT OUTER LIGHT INOP, TAPPED ON LENS AND LIGHT CAME BACK ON ~ ~ ~ ~49876 REPLACE LF REAR UPPER OUTER TAIL BULB
REPAIR# 0140433
DESCRIPTION:
DESCRIPTION: OIL & FILTER SERVICE FOR ALL LS400 / LS430 MODELS. ~ ~OIL & FILTER SERVICE FOR ALL LS400 / LS430 MODELS. ~ ~ ~ ~45662 OIL FILTER SERVICE COMPLETE
SERVICE: STEERING SHAFT UNIVERSL JOINT ASSEMBLY REPLACEMENT
DESCRIPTION: STEERING SHAFT UNIVERSL JOINT ASSEMBLY REPLACEMENT ~ ~CUSTOMER STATES STEERING WHEEL MAKES A GRINDING NOISE WHEN RETRACTING ~ ~LACK OF CLEARANCE ~ ~45662 REPLACE UNIVERSAL JOINT ASSY PER T.S.I.B. ST001-04 ST3002 .9 HRS 45767-50010 T1-44 T2-... READ MORE
DESCRIPTION: TIRE ROTATION ~ ~TIRE ROTATION ~ ~ ~ ~45662 TIRE ROTATION COMPLETE
REPAIR# 0138312
SERVICE: REAR COMB LIGHT BULB, 1-SIDE
DESCRIPTION: REAR COMB LIGHT BULB, 1-SIDE ~ ~REAR TAIL LAMP FAILURE INDICATOR IS ON. ~ ~OPEN CIRCUT ~ ~REPLACED LEFT UPPER OUTER TAIL LIGHT BULB
REPAIR# 0019096
SERVICE: FRONT PLATE BRACKET
DESCRIPTION: FRONT PLATE BRACKET ~ ~FRONT LICENSE PLATE BRACKET PEELING FROM CORNER OF BRACKET ~ ~PAINT PEELING FROM BRACKET DUE TO PPPLICATION PROCESS ~ ~REPLACED PLATE BRACKET
REPAIR# 0016669
SERVICE: 30,000 MILE SERVICE & INSPECTION*PLATINUM PLAN* FOR ALL LS MODEL
DESCRIPTION: 30,000 MILE SERVICE & INSPECTION*PLATINUM PLAN* FOR ALL LS MODEL ~ ~30,000 MILE SERVICE & INSPECTION*PLATINUM PLAN* FOR ALL LS MODEL ~ ~ ~ ~FRONT AND REAR BRAKES HAVE 75% REMAINING ALL TIRE DEPTHS AT 9-10/32
SERVICE: OVER 500 10% DISCOUNT
DESCRIPTION:
REPAIR# 0015575
SERVICE: OUTER REAR VIEW MIRROR ASSY (REMOTE CONTROL TYPE)
DESCRIPTION: OUTER REAR VIEW MIRROR ASSY (REMOTE CONTROL TYPE) ~ ~CUSTOMER STATES SIDE MIRRORS DO NOT RETRACT, CHECK AND ADVISE ~ ~INTERNAL SHORT CAUSING INTERMITTENTMIRROR OPERATINON
SERVICE: ROTATE
DESCRIPTION: ROTATE ~ ~HOWLING NOISE FROM LEFT/FRONT TIRE AREA, CHECK AND ADVISE ~ ~ ~ ~ROTATED WHEELS AND NOISE WENT AWAY, RECOMMEND N EW TIRES IN THE NEAR FUTURE, MICHELIN MXV4 PLUS 900.00 MOUNT/BALANCE AND ALIGNMENT. DUNLOP SPRO T 5000 850.00 MOUNT/B... READ MORE
REPAIR# 0015233
SERVICE: 25,000 MILE SERVICE & INSPECTIONFOR ALL LS MODELS.
DESCRIPTION: 25,000 MILE SERVICE & INSPECTIONFOR ALL LS MODELS. ~ ~25,000 MILE SERVICE & INSPECTIONFOR ALL LS MODELS. ~ ~ ~ ~FRONT BRAKES HAVE 60% REMAINING REAR BRAKES HAVE 70% REMAINING ALL TIRE DEPTHS AT 4-5/32
SERVICE: CODES
DESCRIPTION: CODES ~ ~CHECK FOR ENGINE AND TRANSMISSION CODES, CUSTOMER STATES SLUGGISH GOING UP HILLS ~ ~F ~ ~NO CODES STORED AT THIS TIME, NO FURTHER ACTION REQUIRED AT THIS TIME.
SERVICE: DENT
DESCRIPTION: DENT ~ ~REPAIR ROOF DING 50$
SERVICE: INSTALL INVISIBLE BRA. RETAIL TO BE 495.00
DESCRIPTION: INSTALL INVISIBLE BRA. RETAIL TO BE 495.00 ~ ~CUSTOMER STATES HOOD AND FRONT BUMPER AREA CHIPPING ABNORMALLY ~ ~THIN PAINT PARTS EASILY CHIPPING ~ ~PER DOM, PAINTED CUSTOMERS FRONT BUMPER AND TOU CHED UP HOOD AREA AND INSTALLED CHIP GUARD.... READ MORE
REPAIR# 0013593
SERVICE: 15,000 MILE SERVICE & INSPECTION*PLATINUM PLAN* FOR ALL LS MODEL
DESCRIPTION: 15,000 MILE SERVICE & INSPECTION*PLATINUM PLAN* FOR ALL LS MODEL ~ ~15,000 MILE SERVICE & INSPECTION*PLATINUM PLAN* FOR ALL LS MODEL ~ ~ ~ ~FRONT BRAKES HAVE 70% REMAINING REAR BRAKES HAVE 75% REMAINING ALL TIRE DEPTHS AT 7/32
SERVICE: CHIPS
DESCRIPTION: CHIPS ~ ~CHECK ALL PAINT CHIPS FOR ABNORMAL CHIPPING ~ ~ ~ ~TOUCHED UP PAINT CHIPS.
SERVICE: DISCOUNT 10% ON ALL MAJOR SERVICE INTERVALS.
DESCRIPTION:
REPAIR# 0012598
SERVICE: WHEEL ALIGNMENT
DESCRIPTION: WHEEL ALIGNMENT ~ ~CUSTOMOER COMPLAINS OF VEHICLE PULLING RIGHT ~ ~TIE ROD END OUT OF ADJUSTMENT ~ ~COMPLETED FOUR WHEEL ALIGNMENT
REPAIR# 0012365
SERVICE: DISCOUNT (-15.55)
DESCRIPTION:
SERVICE: DISCOUNT (-23.18)
DESCRIPTION:
SERVICE: OIL & FILTER SERVICE FOR LS400
DESCRIPTION: OIL & FILTER SERVICE FOR LS400 ~ ~OIL & FILTER SERVICE FOR LS400
SERVICE: ROTATE AND BALANCE
DESCRIPTION: ROTATE AND BALANCE ~ ~ROTATE AND BAL 2 TIRES, FRONTS
REPAIR# 0011832
SERVICE: COMB: F. BRK CLPR (OPP SIDE)
DESCRIPTION:
SERVICE: COMB: OPPOSITE SIDE
DESCRIPTION:
SERVICE: COMB:F. D.BRK CLPR ASSY 1-SD
DESCRIPTION:
SERVICE: F.DSC 1-SD (ON-VEH)
DESCRIPTION: F.DSC 1-SD (ON-VEH) ~ ~BRAKES MAKING SQUAKING GROAN NOISE WHEN APPLIED ~ ~IMPROPER FRICTION MATERIAL ~ ~REPAIR AS PER TSB BR001-03
REPAIR# 0011127
SERVICE: 10,000 MILE SERVICE & INSPECTIONFOR ALL LS MODELS.
DESCRIPTION: 10,000 MILE SERVICE & INSPECTIONFOR ALL LS MODELS. ~ ~10,000 MILE SERVICE & INSPECTIONFOR ALL LS MODELS.
SERVICE: CLEANED AND REMOVED GLAZE
DESCRIPTION: CLEANED AND REMOVED GLAZE ~ ~C/ STATES BRAKES SQUEEK, C & A
SERVICE: INSPECTED AND CLEANED
DESCRIPTION: INSPECTED AND CLEANED ~ ~C/S STATES E BRAKE LIGHT COMES ON EVEN WHEN HE DOES NOT ENGAGE THE E BRAKE
SERVICE: NO CODES, ADDED CLEANER
DESCRIPTION: NO CODES, ADDED CLEANER ~ ~C/S ROUGH IDLE AT TIMES ~ ~.
DESCRIPTION: WHEEL ALIGNMENT ~ ~C/S VEH DRIFTS/PULLS RT, CHECK ALIGNMENT ~ ~VEHICLE PULLED RIGHT, NO VISIBLE DAMAGE, ALIGNED VEH AND ADJUSTED
REPAIR# 0097759
SERVICE: 1,000 MILE SERVICE & INSPECTION FOR ALL MODELS.
DESCRIPTION: 1,000 MILE SERVICE & INSPECTION FOR ALL MODELS. ~ ~1,000 MILE SERVICE & INSPECTION FOR ALL MODELS. ~ ~1K SERVICE ~ ~1K SERVICE
SERVICE: RECOMPENSATE COMPASS
DESCRIPTION: RECOMPENSATE COMPASS ~ ~COMPASS IS 1/4 NOTCH OFF ~ ~COMPASS LOST CLIBRATION ~ ~RECOMPENSATED COMPASS TO REAR CORRECLTY
REPAIR# 0096137
SERVICE: PRE. DELV. FOR L/S430 & E/S300 &S/C430 & S/C300 & G/S300, G/S430R/X300,LX470
DESCRIPTION: PRE. DELV. FOR L/S430 & E/S300 &S/C430 & S/C300 & G/S300, G/S430R/X300,LX470 ~ ~PERFORM PDI INSPECTION ~ ~PDI ~ ~PERFORMED PDI
SERVICE: TIRE/WHEEL SWAP COMPLETE (5)
DESCRIPTION: TIRE/WHEEL SWAP COMPLETE (5) ~ ~SWAP CHROME WHEELS FROM STOCK L4422
475320 MILES
DATE: 04/28/2016REPAIR# 0085889
475320 MILES
DATE: 12/09/2015REPAIR# 0083556
459943 MILES
DATE: 07/03/2015REPAIR# 0080279
451117 MILES
DATE: 03/27/2015REPAIR# 0078273
450230 MILES
DATE: 03/20/2015REPAIR# 0078128
449970 MILES
DATE: 03/10/2015REPAIR# 0077962
SERVICE:
445857 MILES
DATE: 01/28/2015REPAIR# 0077265
439859 MILES
DATE: 12/03/2014REPAIR# 0076088
431344 MILES
DATE: 09/22/2014REPAIR# 0309502
430868 MILES
DATE: 09/09/2014REPAIR# 0074303
426301 MILES
DATE: 07/28/2014REPAIR# 0073390
422739 MILES
DATE: 06/28/2014REPAIR# 0072649
421754 MILES
DATE: 06/16/2014REPAIR# 0303664
420995 MILES
DATE: 06/10/2014REPAIR# 0303319
411358 MILES
DATE: 03/25/2014REPAIR# 0070564
SERVICE:
400938 MILES
DATE: 12/13/2013REPAIR# 0068651
388210 MILES
DATE: 08/30/2013REPAIR# 0066324
382047 MILES
DATE: 06/26/2013REPAIR# 0065135
371969 MILES
DATE: 03/27/2013REPAIR# 0063328
368687 MILES
DATE: 02/26/2013REPAIR# 0062750
358295 MILES
DATE: 11/29/2012REPAIR# 0060902
356089 MILES
DATE: 11/01/2012REPAIR# 0060497
348833 MILES
DATE: 08/24/2012REPAIR# 0059105
345620 MILES
DATE: 07/30/2012REPAIR# 0058580
DESCRIPTION:
337517 MILES
DATE: 05/31/2012REPAIR# 0057364
DESCRIPTION:
328240 MILES
DATE: 03/08/2012REPAIR# 0055948
327147 MILES
DATE: 02/27/2012REPAIR# 0055747
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
291971 MILES
DATE: 05/06/2011REPAIR# 0050442
274952 MILES
DATE: 11/24/2010REPAIR# 0047647
DESCRIPTION:
DESCRIPTION:
259397 MILES
DATE: 07/06/2010REPAIR# 0045135
228694 MILES
DATE: 10/30/2009REPAIR# 0204551
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
194316 MILES
DATE: 03/02/2009REPAIR# 0037149
188185 MILES
DATE: 01/16/2009REPAIR# 0189723
157155 MILES
DATE: 06/03/2008REPAIR# 0178311
123893 MILES
DATE: 10/08/2007REPAIR# 0165825
113831 MILES
DATE: 08/01/2007REPAIR# 0162120
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
109095 MILES
DATE: 07/02/2007REPAIR# 0160493
100156 MILES
DATE: 05/11/2007REPAIR# 0157815
60089 MILES
DATE: 08/14/2006REPAIR# 0144921
DESCRIPTION:
49878 MILES
DATE: 06/30/2006REPAIR# 0142766
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
45662 MILES
DATE: 05/10/2006REPAIR# 0140433
DESCRIPTION:
39803 MILES
DATE: 03/27/2006REPAIR# 0138312
35409 MILES
DATE: 10/31/2005REPAIR# 0019096
32077 MILES
DATE: 04/08/2005REPAIR# 0016669
DESCRIPTION:
27590 MILES
DATE: 01/10/2005REPAIR# 0015575
SERVICE: ROTATE
26407 MILES
DATE: 12/16/2004REPAIR# 0015233
SERVICE: CODES
SERVICE: DENT
20557 MILES
DATE: 08/11/2004REPAIR# 0013593
SERVICE: CHIPS
DESCRIPTION:
16953 MILES
DATE: 05/28/2004REPAIR# 0012598
15817 MILES
DATE: 05/12/2004REPAIR# 0012365
DESCRIPTION:
DESCRIPTION:
13392 MILES
DATE: 04/01/2004REPAIR# 0011832
DESCRIPTION:
DESCRIPTION:
DESCRIPTION:
10253 MILES
DATE: 01/21/2004REPAIR# 0011127
2540 MILES
DATE: 08/06/2003REPAIR# 0097759
9 MILES
DATE: 06/27/2003REPAIR# 0096137
Carfax is EXTREMELY spotty. I live in Memphis (GRAB A LOOK-who says that....Doug...), and recently purchased an LS w/186k. It is still sitting at my shop as of today, getting some final touches finished since purchase 3 weeks ago in Hickory, KY at a town w/ a population of 10000. I apd $5500 for the car w/ a Carfax. The car is actually from the Knoxville area. There were hardly any notations on the vehicles' service history. I called Lexus in Knoxville from my shop in an attempt to retrieve any info on the car as it is a two owner vehicle. Last 10 years spent in Knox. Long story short, Carfax is extremely unreliable
the car mfgs have a record of service that is the equivalent of an experian record is for our credit. No fooling around. Maybe it's more like Lexis or Nexis whatever. I have this for my BMW somewhere, and it's not supposed to be given to the owner nor anyone else. Some dealers don't care, and one ran and handed it to me. One verification that I had anything to do with the vehicle? I handed my key, which was inserted into the USB reader. So at least there is some warm and fuzzy that not just anyone could get this info...
200K is probably pushing your luck, but I can see that it is possible. If the car is driven a lot, like 30-40K/year, the miles add up quickly, but age wise, that is only 3-4 years.
Had a Carfax report for an LS I considered. Had virtually no repair work listed. Owner then provided me w/ an extensive repair history done by the local Lex dealer and his indy. If the service provider doesn't report it to CF, it won't be listed. However, CF is useful for owner and accident history.
I am not too familiar with this engine, but somewhat familiar with the v8 4.7L version, which I believe is very similar. I have had Sequoia and now have a Land Cruiser with that engine. From what I have seen, both engine use this pretty good size timing belt. In the 4.7L, I have seen people saying that these belts go for way pass 90K miles, and still look good when being replaced. I think in our Sequoia, it was replaced at ~110-120K miles and it still looks good. I have no doubt that it will easily go for another 30-50K miles.
https://www.clublexus.com/forums/ls-...f-old-one.html
just throwing this out there....i just got my wife's car as a "hand me down" as she got a GL450. we have owned the car for 7 years. she put just about 100k miles on the car. there was no history of the timing belt being done prior to our purchase from a used car lot. and honestly, that just totally slipped my mind in having it done. the current mileage is 197,300. and now it is currently my daily driver. now, i do have an appointment on monday to have the timing belt/water pump done. but to my knowledge that's the 1st time it's been done.
Do not count on Carfax. My 2005 had a carfax guarantee. No accidents. Hmm, I am 100% certain that bondo is not part of our cars.
Be very wary of Carfax. There guarantee is right at worthless. Some online research will tell you just how bad they are.
Collar does not match the cuffs.
