Tiny little rusted metal and stains on moonlight pearl
I am finally at home after picking up my 04 CL. The car was park in a garage, under the garage door mechanism. Unfortunately, there are bits of rusted metal that end up falling on top of the car, on the trunk. So now I have about 10-15 tiny dots, maybe 1-2mm of rust. I can see some of it has little rusty metal, others seems like rust stain. I can try taking picture with my SLR if that helps.
Any thoughts on how to remove these stain, including the little tiny metal without doing more harm to the paint? Appreciate any help!
BCT (07-02-18)
BCT (07-02-18)
I would use this product from Adams Polishes called "iron remover" spray the car with this and then wash it and clay bar should be able to take off all the contaminants including the rust spots. Apply wax or sealant after to help protect it for the future. Good luck
Be a little careful....I have moonlight pearl too, btw!
I have always been able to get away with removing "anything" as long as it didn't cut into the clear, on all our cars. and 3/4 are pearl. Examples are a panhandler dug his handle into my Maxima and put a long red mark on a white car--Meguiars cleaner wax took it right out. My wife's SUV got scraped at pre-school (those parents are pretty nuts), and she was aghast, gonna call cops and accuse another parent (there have been incidents of hit/run). It was very bad but I managed to get all the black scuff out with, you guessed it, Meguiars cleaner wax.
I have this razor thin scratch on the LS430, front driver's door, and it runs parallel to the ground. I leave that alone. It is white, meaning clear and top coats are gone. If I were to touch it with the top coat, it will make the line bigger. This is what YOU DON"T WANT.
So as long as there is no cut into the clear coat, you'll be fine. Try to make sure there isn't any material on the car when you go to clay or polish or cleaner wax it. I'd just use a microfiber and plenty of water. You just don't want to grind anything into the paint. Then I am pretty confident what you have will come off.
edit p.s. I had never used a clay bar until I think 2 yrs. ago? It is a lot of work, but gets very good results. I have gotten artillery fungus spores on my wife's car because of the stupid neighbor's mulch. Those are those little black dots that become super sticky and smear when attempting to remove. Even cleaner wax could not remove--clay bar did with TONS of work. I finally discovered that if you get those fungus spores when they just hit the car, they "can" come off with simply microfiber and water....terrible. They can survive power washing and a car wash, no joke. Also, I used to think my wife's GM car had super cheap paint, it felt rough. After clay? It was as smooth as the BMW...
Any time you physically touch your paint you risk the chance of scratches. Especially if you have to rub something on it. Not saying clay will scratch your paint but it increases the likelihood. Clay works but I prefer iron-x less chance of scratching.
I thought they were tiny bird droppings or insects or something? And oddly, it seems that Penn State University is the expert on it, and I happen to live in PA by coincidence--dunno if that means it's worse here. The spores shoot 20' in the air. Again, I've found if you get them maybe within a week or a few days, with water and a microfiber cloth they can be removed. After that, it's a sticky mess, and yes a clay bar can get them but it's a lot of work as they smear....I hear if they get on the siding of a house, forget it, power washing won't take them off (can't even imagine wiping a house down by hand)....
BCT (07-02-18)
