Figs engineering possible issue
#31
I agree... Even a well worn ball-joint does not have enough play to generate that much noise. In addition to checking for clearance to make sure the UCA is not hitting any nearby parts, as ls430w140 suggested, I would also suggest to detach the ball-joint from the turn knuckle and inspect for play on the other two mounting points (see sketch below). The noise sounds like maybe one of these bolts was missing or something. I don't think your car is safe to drive.
#32
This sounds to me like loose UCA bolts, or uca bushings hitting the area where they are torqued to, or a huge play in a ball joint. I advise to urgently take the car to a good shop for diagnostic as I advised at the beginning of your topic. Looks like it is dangerous to drive your car at the moment.
There is 0 play in the tire test everything is tq to spec.
#33
You already mentioned that you've checked everything and made sure they're torqued to specs and rechecked them again after driving it and everything were still good. I would try this next: remove the wheel and unbolt the knuckle to the ball joint and try rotating just the ball joint itself to see if there's still a noise.
Also, another question: did you have to cut into the body so the arms will have space to move up and down? FIGS FUCA has this design flaw in the early production model I think. I have a friend that has this very similar noise when he installed the FIGS FUCA. It turns out that the arms were hitting the body during suspension travel. I had this exact same issue during my install too. It drove us nuts to try and find the issue. After we cut it, the issue was completely gone.
Just to be clear, this is not a standard ball joint which is a swaged and captured ball stud with a nylon pocket, these are spherical rod ends with machined stud adapters. There in no danger of separation unless the top nut torque and spacer to stud retaining compound were compromised. We always try to assess what the problem is via diagnosis before sending any parts for replacement because there is a good chance it will not address the root cause.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Lukas99GS
Suspension and Brakes
04-29-14 02:03 AM
MashinA
04-28-13 08:09 AM
