Lower steering shaft clunk?
Old 07-07-18, 02:54 AM
Mbodall
Mbodall's Avatar
Yep, I’ll be tackling this soon. Hopefully later today...
Old 07-07-18, 06:58 PM
YODAONE
YODAONE's Avatar
Am interested in images of superseding P.N...
Old 07-07-18, 07:26 PM
bradland
bradland's Avatar
90080-11555
Bolt is the same only the part number has changed.
Old 07-08-18, 08:40 AM
Mbodall
Mbodall's Avatar
Originally Posted by bradland
90080-11555
Really? Nothing is visually different at all between the two bolts?
Old 07-08-18, 08:09 PM
YODAONE
YODAONE's Avatar
One has yellow zinc Dichromate plating and the other is zinc plated
The former is more durable finish ...but not as environmentally friendly plating process
https://www.practicalmachinist.com/vb/general-archive/yellow-dichromate-vs-zinc-plating-73923/
Mbodall (07-09-18)
Old 07-10-18, 06:08 PM
warminwisc
warminwisc's Avatar
Anyone get this done or do this yet?
Old 07-10-18, 06:49 PM
bradland
bradland's Avatar
I only replaced the top one next to the brake pedal then I tightened the most accessible one in the engine compartment and it made such a dramatic difference I stopped there. Super simple and quick! If you can't see the bolt just start the car and turn the steering wheel until you can. No more knocking or steering wheel shimmy in parking lots and over speed bumps!!!
Old 07-12-18, 10:04 AM
Mbodall
Mbodall's Avatar
I just ordered a new bolt from my dealership... they said both 90119-08560 and 90080-11555 part #s have been superseded lol. $4.56 from Kuni Lexus of Portland. Should have it in 2-3 days...
Old 07-12-18, 10:18 AM
Trent430
Trent430's Avatar
I just picked up 3 of them today from the Toyota dealer $5.63 total. I might not get them put in until next week though
Old 07-13-18, 12:56 PM
bradland
bradland's Avatar
Honestly guys you would prob be fine just re torquing the existing bolts. I did the same thing, for $1.44 why not, but in retrospect replacing the bolts may be overkill.
Old 07-14-18, 08:49 AM
jherr
jherr's Avatar
Originally Posted by 02blkgs430
wow my 05 LS430 with 82k miles have the same issue, it gets louder when you go over bumps or bumpy road.
Im gonna try the fix!!! thx
I think I also have the same problem. I was told the steering shaft probably needed to be replaced. This is much simpler option. I am definitely going to try just re-torquing the existing bolts.
Old 07-14-18, 01:26 PM
05ls430518
05ls430518's Avatar
Anyone have the tq specs for the column?
Old 07-14-18, 03:31 PM
rkw77080
rkw77080's Avatar
File Type: pdf
infojunky (06-23-21)
Old 07-15-18, 12:00 AM
05ls430518
05ls430518's Avatar
Originally Posted by rkw77080
Thank you rkw
Old 07-15-18, 05:48 PM
warminwisc
warminwisc's Avatar
Did not work for me, boo hoo.
Quick Reply: Lower steering shaft clunk?
