Questions about the ls430
Questions about the 01 ls430 water pump and timing belt.
My water pump just went out I was wondering how hard it is to change and if I would have to change the timing belt also
There are lots of threads here on your issue as well as a sticky or two about TB service. Read those and you can decide if it is something you want to tackle yourself.
By all means, change the timing belt and related hardware at the same time as doing the water pump.
I have not attempted to date....hope to.
Most people consider this a straightforward job and doable if you have time and patience, plus there is a complete video on YouTube by that guy Nick.
On the other hand, if you pay an indie to do it, the worst it should be is $750 to $900, if you choose not to DIY.
p.s. what is the history of your car, is there a last known date of a timing belt/water pump job? Be curious to know how long the WP lasted...
Get the Aisin kit. Water pump, timing belt, tensioner, idler and the other bits.
I did not dare to do this myself.
One other item you may consider. Change the radiator at the same time.
When you put the new waterpump in, it will have better flow. More pressure. About 3 months after doing my timing belt/water pump, my radiator developed a leak on a seam just below the radiator cap.
Would have been easier to just add that to the list. The radiator was ~$80, so not a lot additional. Plus labor of course.
We'll see if the OP responds with vehicle info...
I really don't know the last time it was changed. I bought it from a guy that owns a title loan company for 1500$. I've had it about 4 years it my daily driver I drive about 80 miles a day. I just drove it 2 and half our drive to Tennessee and then 2 and a half back. I've kept everything else serviced.
this kit any good?
https://m.ebay.com/itm/Timing-Belt-kit-with-water-pump-for-2001-2007-Lexus-GS430-LS430-4-3L-V8-DOHC-/282437285820?fits=Year%3A2001%7CMake%3ALexus%7CModel%3ALS430%7CTrim%3ABase%20Sedan%204-Door%7CSubmodel%3ABase%7CEngine%3A4.3L%204293CC%20V8%20GAS%20DOHC%20Naturally%20Aspirated%7CEngine%20-%20Liter_Display%3A4.3L
this kit any good?
Negative. Don't use a cheap kit for the timing belt and water pump. There are a few things you can cheap out on with this car, but the TB is not one of them.
I purchased the Aisin kit off Amazon and it was about 170.00 dollars.
It's the go-to kit for this car.
And how many miles are on the car?
yea we take it everywhere only other mode of transportation we have is a pickup it's a 98 dodge ram 1500 v6 with right at 490000 on it.
1998 Dakota with a V6 is my workhorse.
It'll be interesting to see what the timing belt and pump look like on your LS.
I'd grab a radiator while you're ordering parts. It's 70 dollar insurance.
Look at getting an idler pulley as well as the tensioner pulley and the Serpentine belt.
