AC colder on passenger side than driver side
When I set both sides' temp to say 22C, the passenger side front vents blow cool air of the set temp but the driver side vents seems to be a few degrees warmer. Could this be a blend door problem? Thanks for any advice.
One side blowing warmer than the other is a classic symptom of the air conditioning being low on refrigerant.
However, there is a possibility that having it recharged may only cure it temporarily. I.e. there was a reason it got low in the first place. Hopefully it's just natural weepage through the A/C compressor bearings. Worst case scenario there's a leak somewhere else.
