Young owner European LS430 factory DRL
Old 07-25-18 | 02:19 AM
MrCorleone's Avatar
MrCorleone
Question Young owner European LS430 factory DRL
Hi,
Three months ago, I bought a LS430 04 from a car dealer with only 52k in almost perfect condition. This is my first V8 engine (came from a good old inline 4). I don't use as a daily because here the gas price is rising... and I need to refuel every week (approx. $140 a tank).
It's the european version of the LS430, so it doesn't come with factory DRL. I wonder if there is a way to activate factory DRL. Something like a fuse or a programmation with the TechStream ? I brought the car to a Lexus dealer and he wasn't able to activate them.
Is it even possible with the European version ?
Old 07-25-18 | 03:41 PM
rkw77080's Avatar
rkw77080
You should be able to switch it On and Off with TechStream...
Old 07-26-18 | 01:05 AM
MrCorleone's Avatar
MrCorleone
I've already tried this solution but the TechStream was not able to connect to my car properly... It did not seem to recognize the car, I had to enter manually the model and the year. After that I never saw the DRL function in the programming section, is it because it's an european version (in France no need to have DRL before 2010) ? Or its an TechStream issue ?
I will try to go further with TS..
Old 07-26-18 | 04:39 AM
DomeSL's Avatar
DomeSL
I also have a european version and it does not list DRL function On/Off at CUSTOMIZE PARAMETERS.
I think it was not available for Europe.
Old 07-26-18 | 08:38 AM
MrCorleone's Avatar
MrCorleone
I think so, but is it a software restriction of the TechStream or the car? I don't know...
I was also looking for the automatic door lock while driving but the option does not exist either.
Old 07-26-18 | 08:55 AM
rkw77080's Avatar
rkw77080
Your other option is to re-wire the fog light (see red arrows) as DRL. That is, to bypass the original relay with a jumper to power these lights directly whenever the ignition is ON.
Take a look at the link below...
https://www.clublexus.com/forums/ls-...n-relay-2.html
Starting on Post #20 for instructions.
Old 07-27-18 | 12:41 AM
MrCorleone's Avatar
MrCorleone
Thanks I think I will use a similar wiring but not to power fog light (the inadvertent use of anti-fog is illegal where I live)
Instead I will use a module for dimming the high beam (like in Canada) with auto turn-off when low beam are on
Infortunatly the european version hasn't orange side-marker in the corner of the head light
Old 02-14-22 | 08:11 PM
ChiefYeet's Avatar
ChiefYeet
So I used to have a 99 camry and read that you could turn off the DRL on that car by engaging the handbrake before putting in the key, you then starting the car, putting it in D and lower the handbrake to not have the DRL on, I tried it today with my 02 ls430 and it worked until I released the parking brake...
mdanfas
06-11-18 02:39 AM
davidgfree
07-27-17 07:59 AM
splitfire
11-06-07 08:23 PM
aussie2u
06-11-01 03:14 PM
