03 LS430 - Disintegrated Electrical Connector
Hello,
After pulling the intake manifold I found a disintegrated electrical connector. The middle section is still there, but the shell around the plug has fragmented. Basically there is nothing to hold it in except the rubber part of the plug center.
Does anyone have the part number for this item? Can this plug be repaired? This is on the underside of the manifold and I don't want to have to do this job again.
Thanks.
Thanks.
Hello,
Thanks.
Thanks.
https://www.google.com/search?q=2586...ZfdIU22OKl0qM:
I found the part numbers for all the electrical connectors in our cars somewhere when I had to replace a few under the hood after doing some work. I also found a document that gives information on taking the connectors apart so they can be replaced. I thought I save it somewhere but i cant find it. You can order most of the connectors from lexus or even find on ebay. A lot of the connectors are used in multiple spots. The plugs actually have their part number stamped on them. If you have the tools and know how you can safely pull the pins and plug them right back into the new connectors.
YODAONE
63
10-18-20 10:35 AM
