Electrical Connectors - Drawing and Part Numbers
After years of service (in some cases under extreme heat in the engine bay), the electrical connectors in our LS430 are getting brittle and are often crumbled during routine maintenance. Attached are sets the drawings identifying connector numbers and their associated part numbers. Most of these connectors are available on Amazon, ebay, or your local Toyota/Lexus dealership. Many are offered by aftermarket vendors.
In addition, you may find the following postings useful:
Complete Set of Torque Specifications for 2001-2003 LS430
https://www.clublexus.com/forums/ls-...003-ls430.html
Complete Set of Torque Specifications for 2004-2006 LS430
https://www.clublexus.com/forums/ls-...006-ls430.html
Mechanical Drawing Set for 2004-2006 LS430
Mechanical Drawing Set for 2001-2003 LS430
Complete Sets of Diagnostic Trouble Codes for LS430
https://www.clublexus.com/forums/ls-...for-ls430.html
Last edited by rkw77080; 09-16-18 at 03:46 AM. Reason: Added links to other related postings
The following 5 users liked this post by rkw77080:
When you R/R your Alternator it’s handy to have a replacement G2 connector # 90980-11349. The retention tab cracks/ disintegrates from the heat and 15 years of life. If the retaining tab breaks the connector backs out of the alternator and you will being motoring on battery for very short length of time. It isn’t easy to replace in a garage. It will strand you on the road if ignored when reinstalling a new alternator if tab is broken. Toyota dealer has this item. Just show them the Illustrated parts call out included in above posting attachment and describe the part. Toyota 3UZ’s I believe use the same part.
rkw77080
04-28-20 08:00 AM
rkw77080
09-19-19 03:54 PM
rkw77080
09-16-18 03:06 AM
