What is actually done at the 120,000 mile checkup?
I don't have a Lexus dealer in town. Closest one is about a 2 1/2 hr drive away. History of taking the Lexus to the local Toyota dealerships has not been a stellar experience. Required maintenance lights have come on for what appears to be the 120,000 mile service check. Before I make the drive and spend all day at the dealership, I would like to determine what services are actually performed as part of the 120,000 mile checkup and what others have paid for this service.
Copied from a 2005 Schedules Service Manual-
o Replace engine oil and oil filter1
o Measure brake pad thickness and rotor runout
o Replace brake fluid
o Replace engine air filter
o Replace spark plugs7
o Replace transmission fluid (ES 330, LS 430)5
o Re-torque drive shaft flange bolts (IS 300, GS 300, GS 430, LS 430)
o Rotate tires (all models except IS 300 Sportcross)
o Road-test vehicle
o Inspect the following:
____Ball joints and dust covers
____Body ____
____Brake lines and hoses ____
____Differential oil
____Drive belts
____Drive shaft boots
____Engine valve clearance
____Exhaust pipes and mountings
120,000 Miles or 144 Months
1 Reset the oil replacement reminder (“MAINT REQD”)
light after replacing engine oil, if vehicle is equipped
with this light.
2 Required only if vehicle is operated primarily in desert,
on dirt roads or while towing.
3 Replace only with Genuine Toyota Super Long-Life Coolant
or similar high-quality non-silicate, non-amine, non-borate
ethylene-glycol coolant with long-life hybrid organic acid
technology (i.e., a combination of low phosphates and
organic acids).
4 Required only if vehicle is operated primarily on dirt roads.
5 Required only if vehicle is operated primarily while towing.
6 If equipped with limited-slip differential.
7 Required under the terms of the Emission Control
Warranty.
o Road-test vehicle
____Body ____
____Drive belts
with this light.
organic acids).
Warranty.
[img]data:image/png;base64,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****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****13OuohBdZeibOkZwDvRXoGsnnUfPzNRdNOhrvXDNLzbxVYe6UHSM8A3ov0DGTzifl42zbzidCDdHCRz4vWn6QtR+SP8u5pnU/hloPzPMunUus2SGkl4Zkmdcp3U5fUonvDbbN0WmsBvq60fDq3bl457pbfakl9d6aTWx1Vn7muqz5nWZZSe7/AVmfqWxj5SWg9g7pj9UeUy2ebm5vqP8tuN5oPHnfvun5CbyA9AxGRnoFsPjEf91Ng/0L9uKSTkkiO49i2TcLZtm3luyYLSqSWciTZ6BCzLMvg2rP7uFV+59bkLtxbM81zi3IrLb8GlCO6H+ryWy0x5ded3Oqo1tOhc+RIga3O1Lcw8pPg9pX5/Eh5PM9z/cuAudZtmNuN5bv6yGkL7yE9AxGRnoFsnpye5bFOJ6ZM/c+y2GkWcUv20mmmuJ2e3fKPRuR1V5TrWzPNq4tqVXr8t8Ypi6Nu+SMtKY/rTm51lPt0rOsqK6/lQb/Akc4caaThptjSqlJ+Z69F/1l2u1FWsvud8zrSMxAR6RnI5sk7N+SxyTqtmFWyUR2UjypFHa+lZ3fZshV56xPupefWWmnJbf30PNISU6l08uk2ZfNcl3LqW3ALHOnMkUa2Ln8lPbs/RW5jykp2qyU3BkIL6RmIiPQMZPOo+bifnsu6cjkia5zmEvN3/3JmSWxTtXOjtTTolqmTU13+cRZ5zeXm1swf/d2GuZVu2+bu3DDld1pi7q7u5FZHuU/HUa2FnxZ42pn141bV9SX6edePT9Oz27BWN9YbTk5beM+jRiuAQaRnIJvnzMfmr+GtiFnI4qX+M7rkFX2mCVKFfl1XvcSoq5bXlpWTO+W7EVNeOqYvr2+tVZFWV9p51WBdvtuSulK3k92Ocs88qs3WpwWedmb9uFW1e4k+uX6dX+dat2FuN+rSSpNOW3jPc0YrgHGkZyCb6POxGzTxi9641Aoj+mgF/iZmKSCb6PMx6flRzA4ZvFf00Qr8TcxSQDbMx0AUjFYgItIzkA3zMRAFoxWIiPQMZMN8DETBaAUiIj0D2TAfA1EwWoGISM9ANszHQBSMViAi0jOQTY75mHfewF+QY7QCfw3zE5BNjvmY9Iy/IMdoBf4a5icgmxzzMekZf0GO0Qr8NcxPQDbPmY+3bXM/UVk+Tbpzvv7M5LoQ+Vzl8lnW+nHnqsGP+wa+5jmjFcA40jOQzUPmY/MZdfJ4nudlWdxLzPlugfLdkonLQf24f1Vdvr5knmc+VA/f9JDRCuAS0jOQzUPm423bdEpelqVk3FZCNedLqHUXpHXkdR/XV7nlm9P0QjXwBQ8ZrQAuIT0D2TxkPn5Lei7p1hw8ztKze1Wr/NZCOPAFDxmtAC4hPQPZPGQ+1js39ONWetZbLCT+6nSrM/Fpeq6v0uW7m0CO41jXlbVnfNNDRiuAS0jPQDbPmY/1C/L0qwZbe4vl1YTlVYDloLwiUB883bnhXiXll9cU1o2st00DH/Wc0QpgHFMFkA3z8alt2+Z5/u1WAIxWICTSM5AN83GLfhu7324LcByMViAmphAgG+ZjIApGKxAR6RnIhvkYiILRCkREegayYT4GomC0AhGRnoFsmI+BKBitQESkZyAb5mMgCkYrEBHpGcjm78zHb3zrjDcWJW8g3Xpb6+836Vc8sP2vNKnzPuWv+DujFcjkcf93A/Ci58zH00+P+hi/fd8/9JbP74pZD0yflzyw/R9Nz+VTLctn8YwX+5zRCmDc4/7vBuBFz5mPH5ifxOfS87vu+sm9N+KB7f9oetafRT/+i+JzRiuAcY/7vxuAF31iPpZ1tUvrx3VYKZ+VrU9Y1/X4+TkmUoV8znY5TT825Zszy0H9EdxyUEiNy7LoouZ5lg/0bhUiddXbM+RbJZpLv00/P6tcV+H2s/7uvc5xr3I/lrzfUYMN6LRf313p7UNlzXVdy+VuM9yqOx2o1QW6bXbrrQ9Kei7fcn+iJD2P//GB9AxERHoGsvnEfNyJRINXSfpZ17UkS3eJrkQTubycUA7qx3KCe6b57uEFGrP2PKmoKgnPLURHwG3b6lswqVTqndTapK7CXKvPf6VzWlfV5fc7arABg+3Xv1SYVHr6fLWeoxbdGPkdafDnpL62fMvtYV2jXDg4UkjPQESkZyCbR6Vn93hZ/9Ord+6apb7cfdwJQKbAqVo176RniU1uIbIqeXrXOmeXuy5taCVUc74u50Z1zInRAAAgAElEQVTn1Fe55Z921EgD6t8rjsazX84sXSG/RHWa0VqMP13cNY3ptLmu171WFrxbNZZv6V8O+y0sSM9ARKRnIJsn79woSgoxf+6vrzoNiONJrjaYnjuFtDrkven5Xue4V7XK73fUSAPG0/O6rjo3yyVuM1pVvzc9u/W66bn81ucOAfMXiamxB6ZGegYiIj0D2TxnPnbzkwlPh5c86suvpudD/Zn++C+06WaYP8G3klldiC5K9uy6d613bujHrfCnmyT9cK9z3Kt0+e4eDLejRhpQ72owwVeXJsmy/BKlN1KbZrSqNh3o1mW2zZjd7Uf358S91j2/1Qa9Ut73nNEKYBzpGcjmOfNx/Tfx1qsG5bVc5YF8V59ZP+6nZ/cVclqpq37VoE5mdSH6iPvXeV2XPlm/6K21dCovhtP9cK9z3Kuk/PJqvNY9uh3VaYDckdv+un/q3yhazXCrNh24LIu70Ou+arBu8+ArKXWl7lMv9z6p5f/TNfLnjFYA40jPQDbMxzglfwFI4EOfY/IdjFYgItIzkA3zMVr0G8D9dlveJvSvAYxWIKI8/wMFUDAfA1EwWoGISM9ANszHQBSMViAi0jOQDfMxEAWjFYiI9Axkw3wMRMFoBSIiPQPZMB8DUTBagYhIz0A2geZj8/a6v9uYbxp8M+APqd/V+KMtuf3Mvv4j4ZbgvmX1Gyu9VE6g0QpA/KHpCvgjAs3Ht5OK+ZztcC4F1tObvd0bD3+n5E+n5+JDP0ukZyAx0jOQTaD5+G+m53Vd5QOoR3wuPT98vZ/0DOCZHv2/TgA3PGc+1p/NIZ9TXTYt1J9p7P49vf7E5rJqKyXXMVQ+1Vk+Y7m0RD5I+fA+h7muwj3itm2kcNMt0hv15bp/ymnmZuteNSecNqBUJHdXZ8eRO6qfx1b/XOoot9iWwR+wfmtN77mXSOFT46fLPbPf+OI5oxXAONIzkM0D52O9rXlSmxb6YUseb9smKXnbtm3bOuuFJsGUuuZ51jlbV1F2L9RV1EdaDT4tvG6h/qe+vHSU7p9931s3K71qThhvQCvhnd5R3c76TDc9n3ZU68ej7/QHrNNat/fcJ+JQP13uTn3TjJGWP3C0AjhFegayec587C4zt/JTJ4HJIqUc76dnebwsS1kg1CHStKrkIbcKc6TV4NPCOy2sL9f9syxL/atC3av6hEsN6KTn/h21nsfT9Hyv2JbBH7B+a9307D4RRyPxny7DdzxntAIYR3oGsnnIfFwihfyzn2OOswQm/5SwO5ieZW9DK6HWl5vEqY+MpOfTPc2vpGe3V80J4w0YTM91gW9Jz+PFusZ/wD6ant1mnDZePGS0AriE9Axk85D52Ox8kKQiqaITO/SS3nEc67pKnF3XdV3XzjvcmTJl54bewKDzcSm8rqI+4rZtpHDTwnrfs1yuNwzIY9Np/V4dacCl9OwWqGt0d03o/hnvqNaPh/lRGeyK05+6Vu8djSfiaKTnuhmdvjUeMloBXEJ6BrJ5znwsr68qD8pBed2YPniotFGfoF9eJsuE5bvuqwaFhDOT23SBrSrcSt3GnxZumPfc6Fwu7dc36/aqPuG0AVfTs1ugdEV5zVynfy51lFuC7MAxxn/A+g3TvScH3SdiqtJzqxmtvjWeM1oBjCM9A9lEnI/f+K5hg6nld02/91Epn/DpPn/4+1K/IuJoBRBgmgFwSaz5WFb46g0G94RIz7/7WYNv94X0/NHyf1Gs0QqgCDDNALiE+RiIgtEKRER6BrJhPgaiYLQCEZGegWyYj4EoGK1ARKRnIBvmYyAKRisQEekZyIb5GIiC0QpERHoGsnnyfPyFN8R449t3AJ/25NEKoIX0DGTz5Pn4O28nF+JN64Dj2aMVQAtzDJDNk+fj7+Ra+WBt4OGePFoBtJCegWyeMx/rzzoucVY+zViOHMdRPurZfGbKPM/y6cpH41Od6/LleOLP10AmzxmtAMaRnoFsnjMf64/TW5blUJuSS/A15+uD8zyXS+qi5BxdgvkwZzZvIITnjFYA45hggGweMh9v26bjb+Hm3fKx1WZdWadhU1Q5x1xlXixIekYIDxmtAC5hggGyech8PJieSwiuTxhJz3X5bkXAYz1ktAK4hAkGyOYh83HZhlHv3JATJD1LCNZJWqdnvaNDP9brzeu6ymO973lZlk7IBn7XQ0YrgEtIz0A2z5mP3VcNynclH8vrCMsD891CXkFYXmJYl69L1u+5QXrGkz1ntAIYR3oGssk9H2/bdvp+GmzbQBS5RyuQFXMMkE3K+Vi/q13/TD5rEIGkHK1AeqRnIBvmYyAKRisQEekZyIb5GIiC0QpERHoGsmE+BqJgtAIRkZ6BbJiPgSgYrUBEpGcgG+ZjIApGKxAR6RnIJsF8LG/krN/y+VF4Uzy8RYLRCvxBTABANs+Zj/XbzF36yBLzUSkPVKdn/QGHg25cgmSeM1oBjCM9A9k8Zz7WIXhZFvn8v1PPX9klPeMtnjNaAYx7+hQF4KpPzMfbtpUl5EsfRKLT87ZtZfm5/vjucqZ8Frd8cHdJllK1rl2ffxyHvmpdV/3YbZW+tlV+fVCfWadnuaRzm9KwsinFXII/iPQMRER6BrL5xHzcSY0dOj3P81xiqC5BTpjnWSdIOadkUClEHtfnl8LL+fqx2yq5tlW+0IWYM02xZiG5vk35/eE4jm3btm1j7RmkZyAi0jOQzaPSs1l/Ncu3knTNRmepRSfO4ziWZemf33msW1WviJvy62Vmc2Y/Pbu3KavR7iX4m0jPQESkZyCbZ+7ckHLcXQqPSs/lZk0hV9NzZzOGztOk5z+O9AxERHoGsnnOfOy+dYaO4Ou69tOw3lmhH78rPbvlmy0WpRC9hcPEa11U5zblZsuRdV3NJcuysAH6r3nOaAUwjvQMZPOc+dhNz/rldJIdO2lYn69f1feW9NwqX17eVx6Ug+Z1jXXJ5Xj9qkGdvwtZctaXkJ7/oOeMVgDjSM9ANszHQBSMViAi0jOQDfMxEAWjFYiI9Axkw3wMRMFoBSIiPQPZMB8DUTBagYhIz0A27nz8v3/+5Ysvvn73a3C0Ang40jOQDfMxEAWjFYiI9Axkw3wMRMFoBSIiPQPZMB8DUTBagYhIz0A2zMdAFIxWICLSM5AN8zEQBaMViIj0DGTDfAxEwWgFIiI9A9kwHwNRMFqBiEjPQDbMx0AUjFYgItIzkA3zMRAFoxWIiPQMZPO1+Xiapmma9n3/TnVPs+976YFt2367LXfca/8X7vr056rVBjke6GeS9AxERHoGsunPx1PldkVfSCqXGvm19pQqLuXIeZ7rnn+l81/36+m57pN1XQ/SM4DHIz0D2Yyk5xI71nWdpmme53sVfTqpbNsmuWokq305Pf9WCWmU9FwSs3a7i0jPAL6D9AxkM56eJZ7Kd/VyYDlHEol8S+KOTipmEVHHF13msiytimrLspRL9IUmIcljXbv8PqAPmsvLbw7lgRyUWtzbqaswN+veqdv/un90e3Sxpna35aUE/WtG6c9Lt1nKrwtpHTS3oE/odHLdFafpufVc91s+kZ4BfBjpGchmPD2XYGqypkkn5q/krQQj5Py6un3fS247LURfqx8c7fRcF1V/S1++LIv+xeDS7XSqMHfauqk6PeuWuLW7La9baC7s36Y87hfSuYXxTq674i3pWZ/D2jOA7yA9A9lc3fesF/AkvZVgrRcsy2ly/GhESVGXWbQqMu3Up5VzzFp4Pz2bTSmt2ymP9S8GshBe307rlvd9d++00/91ejYL8HXtrRuXlVfdh4O32S/EPaivutTJdaKt9z2bVo0817oNpGcA30F6BrIZSc/1n9TliDaYnt2UI2WaVdhWRaaduiJdzqX0LFVfSs+t2zna6dm9007/d9Jzq/bOjZe7E61npJOe3UJaB1t3fS89v7j23PnZCIH0DEREegayGdy5ISuLeodrvXpqEolOPCbBmB0grTIHl2knT92e1uNX1p5bt3O00/Mb155btY9EUtkjfiM914W0Draed9LzDaRnICLSM5DN1X3Pk7dH+TiOdV3NQmx/80BJUeaViLrM/ee+Z1ORbmTr5Yz9/GeKrb91jG1pGLydTu379X3PUmar9pFIKnn0lfTshlr3t6ZLnXwjPZ8+1/pnsq43BNIzEBHpGchmPD3LPyUdmq2oOj3rg/pa8yd+k8iPgffc0GXq7+oAql/gWO/90OvN09h7bvRjZet2TBUmq73ynhu6B9zaW5HU9EYJo1fTs1uIe7C+hcFOvpeeW8/1yDkhkJ6BiEjPQDbvnY8jrucBUZCegYhIz0A2pGcgCtIzEBHpGciG+RiIgtEKRER6BrJhPgaiYLQCEZGegWyYj4EoGK1ARKRnIBvmYyAKRisQEekZyIb5GIiC0QpERHoGsmE+BqJgtAIRkZ6BbJiPgSgYrUBEpGcgG+ZjIApGKxAR6RnIxp2P//fPv3zxxdfvfg2OVgAPR3oGsmE+BqJgtAIRkZ6BbJiPgSgYrUBEpGcgG+ZjIApGKxAR6RnIhvkYiILRCkREegayYT4GomC0AhGRnoFsmI+BKBitQESkZyAb5mMgCkYrEBHpGciG+RiIgtEKRER6BrJhPgaiYLQCEZGegWy+Nh9P0zRN077v36nuhk+08LTMfd/LOdu2ucef3GP4MtIzEBHpGcimPx9PldsVfTQLzvP8ejtfaWHdgHVdR8okPWMc6RmIiPQMZDOSnkuwW9d1mqZ5nu9V9IX0XNq5LMs0TcuyXC3k9fRcEvNbyiQ9o0Z6BiIiPQPZjKfnbdvMsq5ecC3nSOaTb0mg1FnQLNPqgKjLlARcV2To9FzaKSlfmiEHW7Xrf5YCrzagk55NGm49lk52Owd/HOkZiIj0DGQznp7Lmq5JpSb/mX0IrYwo5Py6un3fS3g9LeTw1p5Nai/Mwrlbe6lXR+fxBryYnvU5rD2jRnoGIiI9A9lc3fesl0gljEpgNZlPB1mTBU2xdZlFqyLTznrbsanILBjXtR/eKvUrDTC/P4ykZ1016Rk10jMQEekZyGYkPZdUp1OjHNEG07ObI6VMs1+5VZFpp157PrxsKt9q1X40VqkvNeDFtWfdA6Rn1EjPQESkZyCbwZ0bsh/X3VssTObTmdJkRLMDpFVmqyLDpGf9T5OeW7Uf6lcF3exLDSA946NIz0BEpGcgm6v7nidvj/JxHOu6btvW2bkrj3UeNa9E1GWafc+mItNOHZfdeuWS09qlhf07dRvQf88NXY7bM3ofNukZNdIzEBHpGchmPD0fam9D+afZ7KvTsz6or9U7OqZpMon8GHjPjcl714tL+55btdctlCXnwQb003O9CaReh26dAxykZyAm0jOQzXvnY1ZMgc8hPQMRkZ6BbEjPQBSkZyAi0jOQDfMxEAWjFYiI9Axkw3wMRMFoBSIiPQPZMB8DUTBagYhIz0A2zMdAFIxWICLSM5AN8zEQBaMViIj0DGTDfAxEwWgFIiI9A9kwHwNRMFqBiEjPQDbMx0AUjFYgItIzkI07H//vn3/54ouv3/0aHK0AHo70DGTDfAxEwWgFIiI9A9kwHwNRMFqBiEjPQDbMx0AUjFYgItIzkA3zMRAFoxWIiPQMZMN8DETBaAUiIj0D2TAfA1EwWoGISM9ANszHQBSMViAi0jOQDfMxEAWjFYiI9Axkw3wMRMFoBSIiPQPZfG0+nqZpmqZ9379TXd++72575Pi2be+q4nZRpoRHdSB+BekZiIj0DGTTn4+nyu2KvhD+TFM7sfXt6bnun0tFzfNsGr+uayc9k6T/JtIzEBHpGchmJD2X9Lau6zRN8zzfq+ijgW/bNhNel2W5kZ5frP32SnNJz+u6ds4hPYP0DEREegayGU/PdULVK6blHEml8i1JhHX4EzoF6jKXZWlV1Gmn+y1Tl7Sz/ErgtrNzjrEsS2mtbrN7y63fQFrp2U3M+nakKLeL+pUiHNIzEBHpGchmPD2XdCghzA12VzcbyPl1dfu+lyR6tZAWfZo87lShz+lXId8y59TFmsgrLqXnuh/6p7UqRTikZyAi0jOQzdV9zyWWlXVoCWQlWOutuuU0OX40Ap+oyyxaFdXndNJzXddIO805pv1uC0s5ZulXX97a11Hve+7/+jHyXJxWinBIz0BEpGcgm5H0XG9dkCPaYHp2U6mUqXc+dCrS53QWhlt1vTE962vNLdSX99PzvbXnThf1K0U4pGcgItIzkM3gzg1Z39V7oOvNACZx6lAox802XEm0I2vPp+00x1t1jbRzMD3XyXX6uRHl0+m500Wk52RIz0BEpGcgm6v7nidvj/JxHOu6btumE2crfeq0ZzZd6DLNvmdTkWln6z03WnWNtHMkPbdeSdnad/He9Gy2iNRdRHpOhvQMRER6BrIZT8+HWmct/zS7dXV61gf1tXqnxPTf+1TU6VO+26qobmqrareukXaOpOfSML3bRL+2spN3javpWXZruO+5Mf2M76TnNEjPQESkZyCb987HJnECeCPSMxAR6RnIhvQMREF6BiIiPQPZMB8DUTBagYhIz0A2zMdAFIxWICLSM5AN8zEQBaMViIj0DGTDfAxEwWgFIiI9A9kwHwNRMFqBiEjPQDbMx0AUjFYgItIzkA3zMRAFoxWIiPQMZMN8DETBaAUiIj0D2bjz8f/++Zcvvvj63a/B0Qrg4UjPQDbMx0AUjFYgItIzkA3zMRAFoxWIiPQMZMN8DETBaAUiIj0D2TAfA1EwWoGISM9ANszHQBSMViAi0jOQDfMxEAWjFYiI9Axkw3wMRMFoBSIiPQPZMB8DUTBagYhIz0A2zMdAFIxWICLSM5DN1+bjaZqmadr3/TvV3bDve2nktm2PrcKU8PxexRuRnoGISM9ANv35eKrcruijOa9u542K3p6e6067VMU8z+am1nXtpGeSdHqkZyAi0jOQzUh6LkFtXddpmuZ5vlfRF9Lz59aMb9i2TVLvvYaV9Lyua+cc0vOfQnoGIiI9A9mMp2eJg/JdvThazpGVUfmWhL8657nrxLrMZVlaFXXaKaQxJffrxuho6wbQzrUj7TmOY1mWcgv6Rtx+aP1a0krPboP1vUhRbjv7leLJSM9ARKRnIJvx9FyCoOStfugc3Fcg59fV7fteQudpIcdZel6WRVckj3WDWzdirh1sj3xLP2hdbiKvuJSe68b0T2tViicjPQMRkZ6BbK7uey4JrKzdSvYqwVrvyi2nyfGjke1EXWbRqui0ncfPlKwboJddT9OzOT7YHn1aOccs/epiW6vX9b7n/u8kI0/QaaV4MtIzEBHpGchmJD3XuxfkiDaYnt1gKmXqTQ6ditx2ttae3fRcKrqangfbo2/c3FddbD8931t77rSzXymejPQMRER6BrIZ3LkhG4X1Huj67/4mdOr8ZwKo2QHSKrNVUaudnca8JT1fao+hv/Xp9NxpJ+k5LtIzEBHpGcjm6r7nydujfBzHuq7bto1sKdbBzrwSUZdp9j2bijrtFKfJeOScVkjttKf18srWvov3pmezRaRuJ+k5LtIzEBHpGchmPD0fakm1/NNszNXpWR/U1+odHdN/b0lRB035bqsit51aPwHXGxvG0/Npe8p39RYU/YLLuth3pWe5Kfc9N6af8Z30HBHpGYiI9Axk89752ITO5xvciQE8AekZiIj0DGTzN9OzXpQlOiMK0jMQEekZyIb5GIiC0QpERHoGsmE+BqJgtAIRkZ6BbJiPgSgYrUBEpGcgG+ZjIApGKxAR6RnIhvkYiILRCkREegayYT4GomC0AhGRnoFsmI+BKBitQESkZyAb5mMgCkYrEBHpGcjGnY//98+/fPHF1+9+DY5WAA9HegayYT4GomC0AhGRnoFsmI+BKBitQESkZyAb5mMgCkYrEBHpGciG+RiIgtEKRER6BrJhPgaiYLQCEZGegWyYj4EoGK1ARKRnIBvmYyAKRisQEekZyIb5GIiC0QpERHoGsmE+BqJgtAIRkZ6BbL42H0/TNE3Tvu/fqc7Y9700YNs29/i+761znuzFXv3dJwVXkZ6BiEjPQDb9+Xiq3K7oc0FtXVfdwmVZ6nN+Nz0vy2K68V39MFLaPM+mdrlB0nMspGcgItIzkM1Iei5hq4TUeZ7vVfTpoHYv+Or0/LWG/Up6Xtf1qO6X9BwL6RmIiPQMZDOenrdtM8vPelGznCPhTL5VQtvxM6h1FmJ1mbKKXFfUb6r8Uyd+XZfci2mDPG6lTDkuC97rusrBetm77jRx2ld1//RvqpRTt0GnZ/PP0/vt9JU5Hmi7S1ykZyAi0jOQzXh6LtsPZO25Hy7LJa1AJuT8urp930sQPC2kvvb4GUBN0HR3a1xNz8uy6Ph7eoN1xOz0Vb9/3ErLs+PuWnHTs6l0pB/cx+2fHbwf6RmIiP9RAtlc3fes1x0lSZfopldhy2ly/KjSoSm2LrNoVdRqqknPZr9EaYBeu72dnvVxnUTrJVizLbtVtbm1un86N9XfVOPu3DB90rrfVl/JwrP7XOBDSM9ARKRnIJuR9Kx3KZTjdSKchtOzG9SkTLN62qqo1dTx9Fwq+kJ6Fnr/SaevWv3Tuamin561uk/66dntK/NSSPcPAngv0jMQEekZyGZw54asNeo90HVcMwHL3WJrFkolz42sPY801f1n3YDvp+eilZKlr1r907mpdV3N9gyt861X0rO5I3fTCN6L9AxERHoGsrm677mV5NZ13bZtZEuxDsTmRXW6zP3nvmdTUb+p9T8PLyke3fegqJPxjfS8bZuJ/m7V9aaI0/4xN9V5eeJIej6937qvRsrHe5GegYhIz0A24+lZ/ikRzWwJ0OlZH9TXmj/6m0R+DLznRp1Q3fd77gTN+pLJS8/uOTfSsylEwnSnr1r9078p87JO06Wn6bnVJ+5xc5Do/B2kZyAi0jOQzXvn49byJGrh+mp8Fw0+hPQMRER6BrIhPf+WKH2lF/6Jzr+L9AxERHoGsmE+BqJgtAIRkZ6BbJiPgSgYrUBEpGcgG+ZjIApGKxAR6RnIhvkYiILRCkREegayYT4GomC0AhGRnoFsmI+BKBitQESkZyAb5mMgCkYrEBHpGciG+RiIgtEKRER6BrJx5+P//fMvX3zx9btfg6MVwMORnoFsmI+BKBitQESkZyAb5mMgCkYrEBHpGciG+RiIgtEKRER6BrJhPgaiYLQCEZGegWyYj4EoGK1ARKRnIBvmYyAKRisQEekZyIb5GIiC0QpERHoGsmE+BqJgtAIRkZ6BbJiPgSgYrUBEpGcgm6/Nx9M0TdO07/t3qvu+fd/LPW7bVo5M/yl3bf75K01yXW3V6fmteuV44h+DjyI9AxGRnoFs+vPxVLld0Udj0xvb2TfPc6siExmXZZmmaV3X8l3zz8/R/fxieq5vtrSf9PxbSM9ARKRnIJuR9Fwy0Lqu0zTN83yvoi+k57e0s68ESrO67GZTc6b55+fc6Od+eq4T/+2nkvT8ItIzEBHpGchmPD1v22ZWW/XaZDlH4pF8S7KXjk1mRVNnKV3msiytil5sZ6cN0mw3gpsQLPdr7rGsNEtXmH+etsrU3unncub0c1VYVzTS7eaf5mY76dmk4dZjeUbqqnEJ6RmIiPQMZDOenksElEjnRiXzJ/tWnBJu+pSAWNLzaSE32nnaBh1AtXoJuXW//bXnfujUtff7eVmWVoJ3/9m55Q+lZ30Oa88vIj0DEZGegWyu7nvWq4kSLmVTr4lHerOvm+pEXWbRqujFdrbacPxMw7U6PesjuupOeu60ytQ+2M+txyPdXp9jbk0ztznSDL2OTnp+EekZiIj0DGQzkp7N9oDjv73FxmB6diOXlCm7NfoVvbed0objK+m5c1Om9kvt76fn01v+0NqzflpJzy8iPQMRkZ6BbAZ3bsjWVXf1VJh4pOOXiVNmZ0WrzFZFL7az1YbjYnrubIEYX3t2b6R/+zfS8+ktk56fj/QMRER6BrK5uu+5lTLXdd22rbPJVR7rRGhe4afLNPueTUUvtnOwDbX+e24MpufOTdW1n/bz4cXWukmnt3wjPZvq3CbpXzBIzy8iPQMRkZ6BbMbTs/xTUpfZF6tTnT6or9U7OqZpMkn3GHjPjcmLtlfb2WlDqwq3qOnnG0vrezx9xzq3VW7tnX6u07Ns9qhfdNi/5Xvpud5b0mmSOQdXkZ6BiEjPQDbvnY9ZXAQ+h/QMRER6BrIhPQNRkJ6BiEjPQDbMx0AUjFYgItIzkA3zMRAFoxWIiPQMZMN8DETBaAUiIj0D2TAfA1EwWoGISM9ANszHQBSMViAi0jOQDfMxEAWjFYiI9Axkw3wMRMFoBSIiPQPZMB8DUTBagYhIz0A27nz8v3/+5Ysvvn73a3C0Ang40jOQDfMxEAWjFYiI9Axkw3wMRMFoBSIiPQPZMB8DUTBagYhIz0A2zMdAFIxWICLSM5AN8zEQBaMViIj0DGTDfAxEwWgFIiI9A9kwHwNRMFqBiEjPQDbMx0AUjFYgItIzkA3zMRAFoxWIiPQMZPO1+Xiapmma9n3/TnV/zb7vpYe3bStHpv98v895rj+E9AxERHoGsunPx1PldkWfTlTLspimfjO9zfM8TdO6rr9Vl0nPpTdutMf0oWTxG4Xc63+SdwfpGYiI9AxkM5KeS4Ra13Wapnme71X00VRUR72/lp7dcy5l323bzC9Iy7KQnh+F9AxERHoGshlPz3W6KhFNnyMroPItCXk6FXUWiXWZy7K0KtLqhglpj6533/dOO1vVyWnurxCdRKvv1LSqlKYvlHtxO6dfl5yvl+Glqf0+PLzfQPp30Tle97m5nVYP6DNv/56WGOkZiIj0DGQznp5LJpNMUycknUrLJe45unw5v66upMBLhdT57zQ999vZSoHj6bkuQbdqWRbdA7q1puVX6zJrz1efiJG7GDzuVtHqgda1KEjPQESkZyCbq/ueS6wpS6QSImWXrcl8evetSUWm2LrMooyadkEAAAIeSURBVFWRaacsYYpyyWl6Nu3sVFfOby3NuonWLFS3ekke6/PfmJ5H+rCzft+6i9bxY+C5bvVAfS000jMQEekZyGYkPdcbDOq06uZCN1G5yUnKlN0a/YpaDdb7Ezo5tdXOTnXl8Y30LHc0mJ7L+W9MzyN92Fl7bt1F63inn6UK0vM9pGcgItIzkM3gzg1Zm3SXM4VJRTrnmYxodoC0ymxV1HeaU1vt7FR3Oz1fXXt+e3oe7MPWDb6y9tx6rknP95CegYhIz0A2V/c9T94e5eM4SvTs7NyVxzrMmQ0Dukyz79lUpBu5bZuJhq0y3ba57ayru5GeDy8XHgP7Sepzrtbl7nvu9GH9XBzqPTfcuxg53nquT9Pzvff6SI/0DEREegayGU/P8k8JSXqbRDlNUpE+qK/VOyWmaTKJ/Bh4z406WtXvU6HDdL1vQedUt0y3un6qM5foxuuD5UgnO7qtHaxLn1+/Y12/D03D6tPqu+gc1y1xn+uRHuA9N2qkZyAi0jOQzXvn486K6aM8v533tqwgN9IzEBHpGciG9PzbbflBrxATnWGQnoGISM9ANszHQBSMViAi0jOQDfMxEAWjFYiI9Axkw3wMRMFoBSIiPQPZMB8DUTBagYhIz0A2zMdAFIxWICLSM5AN8zEQBaMViIj0DGTDfAxEwWgFIiI9A9kwHwNRMFqBiEjPQDbMx0AUjFYgItIzkA3zMRAFoxWI6P80N1+/CCpCrQAAAABJRU5ErkJggg==[/img]
You can generate your own schedule at http://consumer.xtime.com/menu/?vari...skipQuery=true - in the URL parameters, change the year, mileage, and units (miles or km) as needed.
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/959x879/120_000_mile_service_52b93bbe5df217d23bea19e15c845a1e10b402b6.jpg)
The forum software doesn't interpret in-line base64 attachments properly and doesn't allow me to edit my previous post. Mods, please delete my prior post, thanks.
Lex Luga
09-26-16 12:22 PM
