Passenger power window
Hello need help I got in my 05 LS today put the windows down and the passenger front window went up half way and stopped . I used the drivers door switch and passenger door switch waited couple minutes went up a little more , waited couple more minutes and closed fully . Came back to the car an hour later lowered all the way down and went back up fine ?? Tried it 7 or 8 more times worked perfect , any idea what’s going on here ? Please
Came out to Lexus today and did it again went down not up wat three seconds goes up little bit wait 3 more seconds little bit up took like 5 times to get up motor is not making any strange noise can’t figure out the problem I read some where after the window goes up keep holding the switch in the up position
got back in car after shopping no problems up and down flawless I don’t know what gives and going on vacation soon don’t need problems with Window
This maybe a long shot, but I will ask anyway... How old is your battery? Does this happen only if the car sit idle for several hours (i.e. problem goes away after running the engine for a bit)?
RKW hi thanks again for the help with my fuses
the battery is pretty new about a year the more st expensive interstate available
and yes to answer your question the car sat for a week Saturday when this first happened then we drive it for about an hour was fine window went up and down no problem . Then sat all night got into today same thing stuck down several attempts after waiting a few minutes goes up in increments drive the car to a couple of stores got back into it everything fine again? Mind boggling my wife said take it in to mechanic tomorrow maybe the motor but no Strange noises as I indicated earlier I’m puzzled
problems then works fine ?
Corroded electrical paths can degrade voltage level delivered to the window motor. This combined with a slightly lowered voltage source can create intermittent failure until a fully-charged voltage source is restored. The corrosion can occur in any of the electrical connectors. You had mentioned that you tried using the driver-side switch and the passenger-side switch with the same result, so we can safety eliminate the switches as being the problem.
rKW you lost me what are you saying? It’s the motor , regulator ? I just went out and tried something I read on this forum lower the window continue holding the switch down then the window and continue holding the switch up
window worked again I’m lost here
Ok this is getting more and more interesting
came out this morning started the car drive it for 5 minutes then tried the window -perfect up and down no issues both switches drivers door and passenger door got to work tried again no issues
cant figure this out please help
It's the motor. I have the same issue but only when the weather is hot.
I recently had my lock actuator replaced on the door and the tech confirmed the motor's performance is degrading. I also thought it was the modulator, and I bought but never installed it, so I am out about $80 for that...
There's a little plastic piece(!) that is prone to fail over time...ask me how I know.
Unfortunately the day after I bought the car the passenger door lock broke and yes expensive I had replaced it now the power window motor a lot of money too Denso thru the Lexus dealer around $500 plus labor
