replacing the radiator
I read a thread here on how to replace the radiator by yourself and it mentioned disconnecting two hoses that carry transmission fluid. Does anyone know how much actually leaks out when you disconnect those hoses? Do you need to elevate them or pinch off the hoses so it doesn't leak out?
Not much leaks out, maybe an ounce or 2. I usually plug the open ends of the hoses with expanding foam ear plugs. Have a pan and a few paper towels handy as the fluid usually drains onto the plastic support for the lower engine cover and drips off of that.
911LE is spot on but don't forget the small amount of fluid that leaves with the old radiator. It will obviously need to be replaced. If you have an earlier 430 with a trans dipstick it's not really an issue but later 430's with an A761 transmission are a little tougher to control the fluid level.
jayjw
10-01-04 06:49 PM
