LS430 CODE P0761 Transmission issue
Stuck between a rock and a hard place with the P0761 code. My 04 LS430 will not shift from 3rd to 4th gear. My mechanic says its coming up with code p0761. I have searched the internet and it seems that this is a common problem with Lexus. Some people seem so fustrated that they have just sold or traded in the car......I have seen the fixes, change Selenoid c or replace dirty transmisson fluid, replace the wire harness.....none seem to work........Would it be cheaper to just put in a used trans and call it a day? if thats the case is the transmission the same for 2001 thru 2004?
2001-2003 LS430 are equipped with the same 5-speed transmission. 2004-2006 LS430 come with the same 6-speed.
Personally, I would not automatically assume that a used transmission will be in better condition. It may not have the exact same problem but odds of something else goes wrong remain the same.
Attached is the troubleshooting procedures for P0761. Take a look, then decide on a path forward.
what would be the cost to have the tranny rebuilt instead of getting a used one? I would always be leary of getting a used tranny.
My tranny has a slight hesitation as well between 3-4 at around 40km. If i have a heavier foot, there are no issues. My mechanic is doing the drain and fill on the tranny this winter with every oil change i come if for. So, by April, i should be at 3 drain and fills. Hoping it will correct itself, lol
From my understanding the transmission fluid level need to be pretty accurate. I think I have read that if there are too much fluid it will cause hesitation when shifting, I would start with checking the fluid level first before even thinking about rebuilding/replacing the tranny. Also I assume you are using the correct Toyota fluid, right?
https://www.clublexus.com/forums/ls-...-04-ls430.html
yes, i went to toyota and picked up about 3 quarts of the WS. Mechanic said that the fluid was dark and to come back next oil change and he'll do it again. According to the service records of the PO, the fluid was done about 80000 miles before i had it done last month. So, not sure why it was so dark.
Not saying that your mechanic is not doing his job correctly, but... how much do you trust him that...
- He changed the transmission fluid
- He changed the transmission fluid with the correct fluid that you gave him
- He make sure the fluid level is accurate
Any or all of the above can cause problem in tranny.
very trustworthy guys. I have a good relationship with them. I gave him 3 quarts of the WS and he used a quart. They brought it up to temp as in his words, `that`s the only way to do tranny fluid drain and fill properly`. They know what they are doing.
ibanezmakki (01-24-24)
I have not drain and refill on my 04 (planning to do this around Christmas - end of year holiday) but from what I read here and what the dealer told me, drain and refill is 2.5 quarts.
I read the same thing so that's why i bought 3 quarts, so not sure, but that's what came out and that's what he put back in. I'd be very surprised if he didn't check the level. I'll ask him again when i go to get another oil change in Feb. Either that or i'll hit up the Toyota dealership close by and get them to do it. I can't do my own as there's snow on the ground now and it's damn chilly.
Car still runs just great, although i would like it to be a smoother shift, almost like i don't feel it shifting, but that's just me.
+1. Something is not adding up if drain and refill only use 1 quart.
My car has 136,000 miles. Transmission fluid has never been changed, as directed in owners manual. I simply cannot tell when the transmission shifts gears in regular driving. Only if I floor it and demand quicker acceleration. Otherwise, smooth as silk.
Just for reference, I've done one drain and fill myself and had my Lexus dealer do the other two. I personally drained ~3 qts out of the pan when I did it and the Lex dealer used a little more than 3 quarts each time as well.
