Handling/Ride Problems - Do I need new struts?
#32
Odds are a salvage yard selling parts on eBay wont even know the difference between a regular and Sport LS430 sway bar. If they claim to know the VIN the sway bar came from you can do a little due diligence. I would also have them send a pic with either dial calipers or an open end 14mm wrench showing the diameter is correct. You could very easily end up with what's on your car already...
#34
I did read somewhere that the earlier 01-03 car seems to have a larger diameter bar because the bushings are larger but I am not sure if that is confirmed 100%. Anyone with 01-03 LS want to volunteer and measure the sway bar diameter? You do not need a caliper, pretty sure we just need to know the circumference of the sway bar to determine the diameter.
gmoney94 (01-04-19)
WCallahan
03-07-03 05:10 PM
