Handling/Ride Problems - Do I need new struts?
Hi everyone -
My LS is an 06 with 105K and it's been a super car since I bought it two years ago with 59k. Over the past year or so, I have noticed a deterioration in the cars handling, especially over 45mph (curves especially - the car really sways and is harder to control), and the ride does not feel as well-damped over common road features (pot holes, expansion joints, etc.). I had the car inspected by my local mechanic, and they said that everything (springs and struts) was within tolerance and not leaking, and they recommended no service. I was ready to have some suspension work done, but they convinced me that it didn't need it and I was just not used to the softer ride of the LS. I'm not convinced as I've had previous LS' that have (in my memory) been far more controlled and damped.
I'm ready to buy front/rear struts for the car, preferably the Sport models, but I don't want to swap out parts that don't need to be changed either. Could folks recommend a definitive strut test for our vehicles?
Thanks!
Thanks!
gmoney94 (12-27-18)
I would have an indie drive it, and lift it. I know when I got my car, Lexus said I needed new struts, and were willing to do them for only $1,800. I thought well that is a really cheap price, but I also hate to replace them unnecessarily (indie said huh? you don't need them, and I'm being sarcastic on the price, a BMW could get top of the line Bilstein coilovers for that much).
I believe our cars are susceptible to needing sway bar end links, though mine were fine at 86k....
p.s. where I live, PA, leaking shocks/struts is a safety inspection fail, torn boots are not...
gmoney94 (12-27-18)
gmoney94 (12-27-18)
Hi everyone -
Thanks!
Thanks!
lorenr (12-27-18)
Bradland is correct. There are a lot of bushings, end links, control arm parts and related inserts that can wear. They all can affect driving. Many of the replacement parts are as good or better than OEM.
That said and since I can't stand it unless I do my own work, I do the whole damn thing. I've found that once I get into it, I replace everything. Seems that every time I decide to "cheap out", I don't find the cheap part.
Would love it if someone made a complete bushing and strut kit.
Loren
Loren
gmoney94 (12-28-18)
- Replaced front and rear sway bar bushings.
- Replaced front and rear end links.
- Replaced front and rear struts.
The first two are the cheapest and easiest, can be done in couple hours. You can see if that fixed the problem. I think it will fix some, especially handling around the curve. However, your description about handling over pot holes and road irregularities, that points to struts. I have not replace struts in LS but have done it in other cars. It is more involved but doable for DIYer.
I agree with the idea that if the struts are leaking they are definitely bad. Having said that I also know that not all bad struts are leaking. Your car (06 with 105K) I assume still has original struts, is 12 yr and over 100K miles. That is a long time without replacing struts. I have had other cars where the struts is not leaking but when I change the struts the difference is dramatic.
I would also check lower control arm bushings. On mine with 125K miles, the fluid filled bushings are not leaking yet but they have cracks, so they will be replaced this coming weekend. These also should be pretty easy to do.
gmoney94 (12-28-18)
gmoney94 (12-28-18)
Hi everyone -
Thanks!
Thanks!
I suggest looking at your tires first.
LS430 quality of ride highly depends also on proper wheel alignment, proper torque of all bushings (or retorque after considerable mileage to ensure tight connection), wheel balancing, and making sure LCA bushings dont have cracks in the rubber. These are the first things to consider based on my experience.
