DIY How to fix Engine Injector ticking noise / Fuel Pulsation Damper
#32
Hey guys, I replaced these fuel dampers with OEM ones and it seems that I've got the opposite result. The vibration of the engine increased and you feel it inside the cabin.
What can I do?
What can I do?
#33
(1994 LS400)
I just replaced my fuel damper. OEM part is discontinued and replaced by part#23270-50012 (mentioned earlier in this thread).
Haven't drive tested yet. BUT the screw on top of damper does not move positions when car is off, or idle, or reved up. And my engine ticking noise is slightly lowder now with new damper.
Thoughts?
Thank you
Thoughts?
Thank you
#34
(1994 LS400)
Thoughts?
Thank you
Thoughts?
Thank you
#36
Have you looked at possible carbon build up in the engine? Has the throttle body been inspected for possible ineffective work causing wrong airfuel mixture?
#37
I just used the wrench. Do not forget to use new gaskets. Good luck!
916LS (11-19-20)
#38
do you have an interchangeable head torque wrench? how did you torque it to spec?
#39
Update.
Replacing fuel dampers was one of the best decisions I made lately to improve comfort of driving my ls430. As of today, I am noticing consistent smoothness of acceleration, which far exceeded the smoothness level achieved by switching from bad to good MAF sensor.
I do believe returnless fuel system in cars like ls430 requires (!) clean fuel filter, properly working fuel pump and appropriate fuel pressure (!) all the way from gas tank to the injectors in the fuel rails.
So far I am extremely happy with this DIY and recommend forum members to look at these parts if you want to restore Lexus smoothness if other methods haven’t worked or if you are just considering a substantial improvement in quality of your everyday rides to work.
You you still here!
a week ago friday my 2001 gs430 thrown the fault code on the way home and straight away realised the engine power is so turned down..
at home checked the code and p0325 knock sensor.
Silly question ,but maybe faulty damper causing knock.sensor code? Just because there is a video and this tapping noise very likely coming from the damper.
heidihidin
ES - 5th Gen (2007-2012)
04-01-18 04:43 PM
