AFS Sensor
02-02-19 | 11:58 AM
AFS Sensor
22 below it prolly iced up and failed here in frozen tundra. Which usually goes front or back? L
02-03-19 | 07:46 AM
The rear one seems to cause the most problems. Corrosion and rust on the inside causes the malfunction.
02-03-19 | 08:41 AM
02-05-19 | 05:08 PM
02-05-19 | 05:23 PM
Quote:
Originally Posted by
warminwisc
I don't think you listed the correct part on this post. That was only a mechanical linkage. There isn't any electronics package with that listing.
I think this is what you'd need for the rear sensor....------->
Rear AFS sensor linky
02-05-19 | 05:24 PM
The first one is what you want. The second one is just the arm. Take note of the old senors position that way your lights are aimed correctly with the new one. Also the the sensor should be located on the left rear.
02-07-19 | 06:30 PM
Thanks never replaced one. My first one busted I traded it in. Does the link itself bust or what? Thanks
FWIW now that it warmed up no light for 3-4 days
02-11-19 | 01:18 PM
If the link broke the light would stay on. Don't be surprised if it comes back on. Mine has done the same thing. Off and on at times.
02-11-19 | 06:47 PM
Thanks. Lite still off. My first one would come and go daily almost. This one off 5 days since 24 below hoping for the best
02-17-19 | 10:40 AM
Still off I am good with that, knock knock Might of just been it was 25 below w/o wind and froze up
hoothoot
11-28-19 05:01 AM
ecaban
02-12-18 12:31 PM
wildwheels
ES - 5th Gen (2007-2012)
07-28-12 01:15 PM
garvard
RX - 1st Gen (1999-2003)
04-07-06 09:23 AM
